A bit dissappointed with polishing forks??
Old Feb 5, 2013 | 12:48 PM
98 FXSTC's Avatar
98 FXSTC
2nd Gear
I started out by using a small palm detail sander (the mouse) with 200 to 400 paper. Using the palm sander removes all the clear finish and also removes nicks and casting marks. Continue sanding using 600 and 1000 wet sand paper. Follow up with 000 and 0000 steel wool using rubbing compound (which is equivalent to 2000 to 2500 paper). Start polishing using a cotton buffing wheel with rubbing compound. If you still have minor scratches use the 1000 paper followed by 0000 steel wool and buff again with rubbing compound. When you combine that with a cotton wheel on a drill and the rubbing compound which generates the heat to cut thru the fine scratches but will leave a dull finish. Final buffing with new cotton wheel using mothers alum polish or equal, the last picture shows the finished results. This method works and the results are flawless.
Attached Thumbnails A bit dissappointed with polishing forks??-mouse-sander.gif   A bit dissappointed with polishing forks??-dsc01059.jpg   A bit dissappointed with polishing forks??-dsc01057.jpg   A bit dissappointed with polishing forks??-dsc01058.jpg   A bit dissappointed with polishing forks??-dsc01071.jpg
Old Feb 5, 2013 | 12:49 PM
cruzomatic's Avatar
cruzomatic
Hey all thanks for your suggestions. I just finished up a whole other round of the 4 grits of paper and it is getting better. I wasn't able to go pick up a lower grit this am as some of you suggested. I'll keep at it. What I didn't do was polished until it turned black? Maybe I just need to keep going at it full speed. I don't have a polishing wheel for my drill or a mother ball, but do have a dremel? Will that work with a little polishing wheel?
Thanks,
Old Feb 5, 2013 | 01:05 PM
ColinSiR's Avatar
ColinSiR
The dremel will work but all your polishing wheels are going to be small and it will take forever! You will save alot of time if you go buy a mother polish ball or a buffing wheel.
Old Feb 5, 2013 | 01:30 PM
tbonetony06's Avatar
tbonetony06
Chrome is king. Get them chromed and your done with them. I'm not into the blacked out stuff but that would be the 2nd choice, then again your done with them. Costs more but you get what you pay for. You just going to have to polish them again when they start to oxidize somewhere down the road. BUT, it's your bike so good luck!
Old Feb 5, 2013 | 01:57 PM
cruzomatic's Avatar
cruzomatic
@tony.... I wouldn't even know where to begin. I'll have to see if there is a local chrome shop here in town. I'll have to check around.
Old Feb 5, 2013 | 03:19 PM
SoCalSoftailSlim's Avatar
SoCalSoftailSlim
Sorry didnt read whole thread. Is the goal to make them look chrome?
Old Feb 5, 2013 | 03:39 PM
sjbodie's Avatar
sjbodie
Im a DIY'er at heart. I don't mind getting dirty and respect anyone who does.
However, if you don't mind turning a wrench........You could just trade out your fork lowers with some fresh chromed ones that you purchased on Ebay. They're about $150-$200. Its Much less labor! You could lower your front end at the same time. You'd be done, in an afternoon. Don't forget your Manual.....You'll need it.
Old Feb 5, 2013 | 03:41 PM
cruzomatic's Avatar
cruzomatic
Yea pretty much and to erase a scratch this is already gone with all the sanding that I've already done.
Old Feb 5, 2013 | 03:46 PM
schlacker's Avatar
schlacker
I feel your pain bro. The whole hand polishing/sanding thing has never worked for me-so I pretty much gave up on it. The best results I have ever seen (& granted I HAVEN'T seen everything) were done by disassembly & machine polishing.
Old Feb 5, 2013 | 04:06 PM
cruzomatic's Avatar
cruzomatic
Man, I'd hate to have to take them off, but I can and will if I have to.
