Stock front caliper banjo fitting size?
Old Feb 5, 2013 | 07:25 AM
tincup64's Avatar
tincup64
Default Stock front caliper banjo fitting size?
does anyone know the size of the front brake line to caliper stock banjo fitting size for a 2013 slim?
i'm considering swapping to the brembo front caliper and want to know if i need to replace the brake line to the ABS module. i hope not.
i already have the new hd brembo caliper and the 11.8 rotor. i'm hoping not to have to swap brake lines.
thx - tin
Old Feb 5, 2013 | 07:56 AM
fergml's Avatar
fergml
Great timing. I was going to order the Street Glide Brembo front brake this afternoon (part number 43027-08) for my 2012 Slim. I'm also going to an 11.8 front rotor.
I asked my local dealer on the banjo sizes and need for a new brake line... no one knew the answer.
I inquired about need a larger master cylinder given the brembos have more surface area and they said that I should be fine with the stock one.
Please post your progress and what you find out regarding what parts you need to make the conversion. Thanks
Old Feb 5, 2013 | 12:10 PM
tincup64's Avatar
tincup64
will do. thats the same caliper i got. it looks like the stock banjo and brembo banjo are the same size (according to online sources) but i won't know for sure for a couple of weeks. i will post results.
tin
steveh326
Apr 19, 2015 06:02 PM
WiscoKid
Apr 28, 2014 03:53 PM
BSR
Dec 14, 2012 05:19 PM
scarabsport
Apr 18, 2012 08:42 PM
Kreuzen
Feb 2, 2007 11:09 AM
