Ahhh, screwed something up, HELP.
Old Feb 11, 2013 | 08:47 AM
zonutt's Avatar
zonutt
Default Ahhh, screwed something up, HELP.
Ok guys, I wanted to remove my front turn sigs for paint, so I pulled the main fuse, removed the tank to access the turn sig connection, unplugged the connection, it's plug and play so it was quite simple, and painted the turn sigs. Then a cpl of days later replugged the turn sig connector, reattached the tank, replaced the main fuse, and turned everything on and my left turn sig is continuously on, but my right turn sig no longer works, and neither do either of my rear turn sigs/stop/run Lights. When I turn the left blinker switch on than the front left turn blinks, but the other lights remain off even when I hit the right blinker switch. What did I do wrong? I don't see how I screwed anything up as its just a plug and play operation.
Old Feb 11, 2013 | 09:02 AM
spydyr's Avatar
spydyr
Did you plug them in the wrong connectors, left to right, right to left, by chance?
Old Feb 11, 2013 | 09:05 AM
883drummer's Avatar
883drummer
i had a problem with one of mine this past winter and it ended up being the piece the white piece that hold the wire in place wasnt working right i ended up just getting a new signal light
zonutt's Avatar
zonutt
The front turn sigs are attached and connect into one connector, which you then plug into one connector. It's plug and play, should have been very simple. I'm very frustrated.
Old Feb 11, 2013 | 09:12 AM
QC's Avatar
QC
Check your grounds after paint.
Old Feb 11, 2013 | 09:26 AM
Bluraven's Avatar
Bluraven
Since everything worked before you dismantled things, my guess is you have either a pinched wire/s or bent pin/s in the connector? Perhaps even a combination of the two.
Old Feb 11, 2013 | 09:31 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Have you checked the bulb? Start simple.
Old Feb 11, 2013 | 11:04 AM
zonutt's Avatar
zonutt
Well, ive taken everything apart again, looked at the connector, it looks fine. I replaced the bulbs in the rear and guess what, they work again. Brake/ run/ turn, everything's good back there, HOWEVER, the front sigs are still not working. I've replaced the bulbs up there, and the front left is constantly on and WILL blink, the right is off, but if I take the bulb out and turn it around and just hold it in, it lights up. Aagh. During the painting process could paint have gotten inside maybe? None of the wires are crimped or damaged. WHYYYYY? What's going on???
Old Feb 11, 2013 | 01:35 PM
jay72's Avatar
jay72
As was said above, check the ground.
Old Feb 11, 2013 | 04:30 PM
QC's Avatar
QC
And do you have the correct bulbs in the correct places?
