Stripped her down
Old Feb 11, 2013 | 08:26 PM
Helrazor's Avatar
Helrazor
Question Stripped her down
i ilke the look and im searching for the perfect solo seat, my question is where to relocate the electrical under the passenger pilon?
Old Feb 11, 2013 | 11:24 PM
Vic Bronco's Avatar
Vic Bronco
The ECM shouldn't be sitting under the pillion, it should be under the back half of the rider seat, unless Heritages are drastically different than virtually every other softail I've seen with the seat off. If you are talking about a solo seat in the sense of a C&C Solo or a LePera Barebones, they should fit over top of the ECM the same way the stock seat does. If you mean a sprung solo seat, whoever makes the seat can probably point you to a battery cover to go under the seat that would probably also cover the ECM. I know guys doing a spring seat on sporties had to relocate their ECM's, but I don't think it's strictly necessary on softails.
Old Feb 12, 2013 | 05:36 AM
jreichart's Avatar
jreichart
+1 on above. If you really want to make it go away, it can be relocated to the area in front of the rear tire splash guard. You'll then need to find something to fill the plastic recess in the fender, but the ECM will be gone anyway. There were a coupl threads about this recently, try some of the threads I linked to below, they might be able to help you out a bit more! Good luck, and remember, pics are required or the mod never happened!
https://www.google.com/search?q=ecm+...&client=safari
Old Feb 12, 2013 | 11:44 PM
Helrazor's Avatar
Helrazor
thanks for the links ill post pics when i get the seat
Old Feb 13, 2013 | 05:34 AM
oct1949's Avatar
oct1949
Since I know of none that's under the pillion seat, it should be an easy fix.
Unless Ur talking bout the wiring that's under the rear fender.!
Old Feb 13, 2013 | 06:50 AM
Tracker56's Avatar
Tracker56
Take a look at Mother Road Customs, they offer some great packages for Softails. http://motheroadcustoms.auctivacomme....aspx?sid=4811
Old Feb 14, 2013 | 10:53 PM
NDBadlands4-2's Avatar
NDBadlands4-2
Do you have a picture of what wires are under the pillion seat? There is no wires under the rear seat on mine.
socialoutcast
Mar 10, 2014 03:49 PM
Haxxor
Aug 24, 2012 06:56 PM
jagsfan811
Jul 15, 2012 12:35 PM
mpaquette
Apr 27, 2009 12:55 PM
tree88
Dec 7, 2007 05:56 PM
