Harley #67800055 - LED Bullet Turn Signal Kit - Smoked Lens
Says it will only work with the following models:
Fits '12-later FXDC, FXDF and '11-later FLSTF, FLSTFB and FLSTSB models. Does not fit FLSTSE2/3 models. Not compatible with Layback License Plate Kit P/N 60215-06.
Is that because the newer turn signal module supports LEDs?
Will it work on older models (2009 FXSTB) if I use a load equalizer?
Think I read that in 11 Moco change the elc's on the bike. don't remember what it was called, but if the book say's if won't fit,, Usually it WON"T fit or work, or both..
U might just give Ur dealer a call, they U'd know for sure and get ur answer in just a few minutes.
I would just go to custom dynamics and buy leds for the stock housings and you should be fine. I understand that 09 and up will adjust to the leds. the ones harley offers are for the new elec systems the new bikes have. Mine has all led lights turn brake and headlight
