How do I remove these brackets?
Old Feb 24, 2013 | 08:34 PM
Bone Doc's Avatar
Bone Doc
Cruz,
I am with you that the lower saddlebag bracket with the rubber bushing is an eye sore. I tried to find a chrome socket to fit over it or even a chrome spacer to cover it. Before I found one I put floorboards on which required using the saddlebag bracket relocation kit. The brackets in the relocation kit are black to match the frame and do not have a rubber bushing on it.
They do not look as bad without the saddlebags. You may prefer it over having to remove and replace the pegs and peg mounts everytime you take the saddlebags on and off. If you use them they are placed behind the frame and screw onto the peg bolt. You may require a longer peg bolt and a nut.
Saddlebag relocation kit
HD part 90238-00
$14.95
Just offering you an alternative.
Old Feb 24, 2013 | 09:11 PM
cruzomatic's Avatar
cruzomatic
Originally Posted by Bone Doc
Cruz,
HD part 90238-00
$14.95
Ahhhh...I didn't know those existed. That is a great option. I'll look into those. Thanks for the intel and for sharing the part number.
Old Feb 25, 2013 | 06:29 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Don't forget to use a bit of loc-tite on those bolts or they could come loose on you down the road.
Old Feb 25, 2013 | 06:52 AM
jadlh's Avatar
jadlh
Yeah, that's a positive on coming loose. On my Fatty I took off my passenger pegs and bought some JP passenger floor-boards. One of them spins to a crazy position if I'm not riding two-up and even when riding two up my wife tells me ..."hey that floor-board is moving again". I spin it until it is almost tight and then it lasts for a few weeks before it starts to spin. On the other side of the strut behind the peg (floor-board) it feels like carriage bolt, nothing a tool could hold onto to tighten.
Got any ideas?
Old Feb 25, 2013 | 07:13 AM
If it really is a four sided carriage bolt first try marking the bolt head with a pencil or marker pen, so you know EXACTLY how its in there now.
Then take everything off and rotate the bolt head 180 to 270 degrees clockwise when viewing the bolt head and reassemble it to see if it tightens up properly.
You may have to add a thin washer or two to get it to tighten up 'sooner' in its rotation cycle.
But once you have the right combination of bolt position and washers clean the threads with some degreaser put on a little lock-tite and tighten it into its final position.
That should cure the problem for you.
Old Feb 25, 2013 | 11:02 AM
hspring03's Avatar
hspring03
Then take it to the next level and send it all out to be chromed.
Kile
Sep 7, 2017 07:52 AM
jurakat1111@gmail.com
Jul 7, 2016 10:53 PM
mtiberio
Jun 12, 2014 04:30 PM
chunks
Jul 2, 2009 05:21 PM
flyboyron
May 5, 2009 03:34 PM
