2006 engine upgrade
Old Mar 1, 2013 | 10:24 PM
moomba's Avatar
moomba
Default 2006 engine upgrade
I have been searching all of the great informatiom on the forum. But i still have questions as usual.
I would like to get the most out of my 88 and need help deciding on the 98 or 95 big bore kit and the best cam.
Currently have a PC5 SE heavy breather and V&H 2 into 2 big radius.
What kind of budget am I looking at. I can turn wrenches, just a bit hesitant to jump into it. Don't want to f$&@ anything up.
Thanks
Old Mar 1, 2013 | 10:35 PM
Dan33klein's Avatar
Dan33klein
I would go 98"
If your boring out your cylinders you may as well get the most displacement.
Cam depends on what you want out of it.
Old Mar 1, 2013 | 10:48 PM
MAJOR's Avatar
MAJOR
I bored mine out to 95 with se flat tops and andrews 26 g cam. I'm no mechanic but rhe job went pretty uneventfully. 20k miles on the build and no issues. Plenty of videos on the net to help you.
Old Mar 1, 2013 | 10:59 PM
Dan33klein's Avatar
Dan33klein
x2 and theres plenty of big bore threads on here with a lot of info
Old Mar 2, 2013 | 12:03 AM
KumaRide's Avatar
KumaRide
That is a very good and common build. Reliable, no ping, affordable. With your 06 heads and 26's, no headwork required. Also a 2n1 will do much better then your 2n2 big radius and if you are spending $$$, pipes are an important part of the build. Skies the limit on builds and their is no "best" build. Take your time and research...
Old Mar 2, 2013 | 03:15 AM
olongapo1's Avatar
olongapo1
A few recommendations:
1. Don't go to crazy on your build and sacrifice reliability.
2. Buy your parts or at least the majority of them from a reliable shop that will help you plan the build and check the compatibility of different parts.
3. Prepare a detailed written plan prior to starting.
Old Mar 2, 2013 | 04:47 AM
tbone108's Avatar
tbone108
Hello there
I have an 05 model fxdxi and its an 88/95 which has been fitted after run in miles. Mix of S&S gear drive cams and Screamin eagle cylinders pistons heads intake exhaust etc. Just to say IMO the 95 has every thing that most people could want out a Harley and is not to radical that would up set the life of the motor. Things have moved on and you have a lot more options now. When i changed things over i had a trued crank so the run out would allow me to go gear drive cam set. There is the screamin eagle cam plate and oil pump upgrade which may be a safer way to go if there is more than 3 thou run out on the crank. Hope this small point helps.
tbone.
Old Mar 2, 2013 | 10:00 PM
moomba's Avatar
moomba
Thanks for the replies guys.
johnnydIII
Feb 28, 2014 07:41 PM
johnnydIII
Exhaust System Topics
Feb 14, 2014 10:34 AM
mja52403
Jul 30, 2012 09:15 AM
06hdsb
Mar 27, 2011 12:36 PM
tnt
Dec 1, 2006 06:54 PM
