My seat won't stay on the bike......
Old Aug 15, 2005 | 09:15 PM
Beefcake's Avatar
Beefcake
Default My seat won't stay on the bike......
I have a 95 FXST. The hole on my rear fender where the back of my seat gets screwed in has come loose. More specifically, the sleeve that the bolt screws into has come out. Would a little crazy glue keep that sleeve in it's place?
Old Aug 15, 2005 | 09:49 PM
AceArt's Avatar
AceArt
Default RE: My seat won't stay on the bike......
If it's like my 05 FXDI, there is supposed a plastic "C" type washer between the seat and the fender. It is what holds things together. $1.89 from H-D for the nut and washer. I have absolutely no idea how I know this info. Art
Old Aug 15, 2005 | 10:08 PM
pococj's Avatar
pococj
I took my rear fender off and had my welder TIG a I' long x 1" wide x 1/4" thick piece of steel that I'd pounded into a curve to fit the fender profile. Drilled & tapped, and permanently fixed. Would've used just a nut, but the hole in my fender was pretty well chewed up & enlarged.
Old Aug 15, 2005 | 10:18 PM
HDF Tech's Avatar
HDF Tech
If you go to the dealers and get the setup for the newer bike like mine 03 deuce, you can enlarge the fender hole and put the threaded nut in it and the clip that holds it in from the top and your done
Matt990724
EVO
Oct 14, 2017 12:19 PM
TooEasy
Apr 21, 2016 02:41 PM
blueangel73
Aug 7, 2014 09:09 PM
Brewser80
Apr 5, 2014 03:55 PM
jcd15
Oct 13, 2007 06:54 PM
