Jackshaft Coupler
Old Mar 4, 2013 | 05:52 PM
Stetler17's Avatar
Stetler17
Default Jackshaft Coupler
Before you ask. I searched and found a ton of information, just not what I need specifically. Manual is ordered but not here yet and from some of the search information, maybe not very clear on my issue either. So any insight from the Harley veterans would be much appreciated.
Putting my primary back together and I'm a little stumped on the coupler for the starter jackshaft. It has a circlip inside it that is offset from the centerline.
Two questions since I didn't pay enough attention on disassembly
1. Which way does the coupler go? It appears that wide side out fits best, but I want to verify.
2. When I torque the bolt for the assembly down to 100 in/lb, should it bottom out on the jackshaft, or should the spring be holding it out away from the shaft end?
Thanks for any help...
Old Mar 4, 2013 | 06:37 PM
seehogs's Avatar
seehogs
The concave (cupped) side goes toward the starter.
Check out this site for parts diagrams.
http://www.shopronniesharleydavidson.com/
The bolt will bottom but the pinon gear will move
Old Mar 4, 2013 | 09:45 PM
Stetler17's Avatar
Stetler17
Thanks for the help...
Found some info to ignore the factory torque value and just snug up the bolt instead. I used 50 in/lbs. with a new locking tab.
Fired right up when I was done, so hopefully all is good.
FreedomRider
EVO
Oct 2, 2017 06:54 AM
95 Ultra
EVO
Jan 20, 2015 05:50 PM
IceMedic75
May 30, 2014 01:25 PM
marksjeff
Ironhead
Jun 17, 2009 09:51 PM
Jameson
Jul 7, 2007 04:16 PM
