Tank Lift Question
Old Nov 2, 2021 | 12:25 AM
IOGOD's Avatar
IOGOD
Stage III
Default Tank lift.
Originally Posted by inkdemon
You can always add a spacer and longer bolt to raise the lower end/level the tank.
Yes, I've made my own. The front is coming in at 1.5,” and the back I believe will weigh in right at 3/4”. I'm not done yet but I believe it's going to work, with elongating the holes at the rear of the tank. I'm not so certain about the look, but I'm all in for cooling that back cylinder as much as possible....
Old Oct 19, 2022 | 02:08 PM
Rabblerouser92's Avatar
Rabblerouser92
3rd Gear
I've ran the DK Custom lifts on my old Softail. Keep in mind it can affect your handling slightly and your fuel gauge readout depending on how high you go. For a clean install you will likely need to modify a few things such as the fuel tank rubber trim, etc. It does provide easy access to clean your rocker boxes which is nice.
Livnoutdoorsxd9
Oct 19, 2021 10:53 AM
Bagger_Vance
Jan 5, 2020 11:30 PM
hutchison101
Aug 30, 2009 02:59 AM
Lone Watie
Dec 14, 2007 08:53 AM
2_up_FXDI
Sep 27, 2005 06:15 PM
