turn signal relocation
Old Mar 23, 2013 | 01:08 PM
blkline69's Avatar
blkline69
Question turn signal relocation
i am trying to relocate my turn signals to my forks, but the dealer says that because my 2011 FXS has a BCM, the wires are ran different then the older bikes, and i can't do it. are they blowing smoke up my a$$ or is this true? has anyone done it? and before you say it, yes, i have searched the forum before i posted this, thanks in advance.
Old Mar 23, 2013 | 01:43 PM
Misbehaven's Avatar
Misbehaven
They are full of crap. Look here at the write up I did.
https://www.hdforums.com/forum/softa...fatboy-lo.html
Old Mar 23, 2013 | 05:29 PM
Deadanimal's Avatar
Deadanimal
Yup full of crap!
All you have to do is cut them between the pods and the switch housing rignt about in the middle as there is just a little bit of wire to mess with, and add the length needed to run back down through the bars to where you want them mounted. I added my own connectors that you can get from J&P or any other distributor so I can disconnect them when I need to. I soldered and used wire loom to make it look factory.
Old Mar 23, 2013 | 05:37 PM
blkline69's Avatar
blkline69
hey thanks for the heads up guys, appreciate it! i've done this myself on my last two bikes, and thought the dealer was full of it. next weekend project...
Old Mar 23, 2013 | 05:49 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Just wondering why you won't to move them.
Old Mar 23, 2013 | 08:26 PM
blkline69's Avatar
blkline69
because i don't like how they clutter up the bars
Old Mar 23, 2013 | 10:23 PM
UT-rckr's Avatar
UT-rckr
Sounds like you should avoid that dealer from now on
Old Mar 24, 2013 | 04:47 AM
Deadanimal's Avatar
Deadanimal
there is also this too. I might redo mine like this as I have turn mirrors also and moved the pods to the trees.
Old Apr 6, 2013 | 07:37 PM
Darkrider1's Avatar
Darkrider1
Dealer just trying to make a buck Of course it's YOUR buck he wants!
Schwanz583
Jun 22, 2015 05:35 AM
Tbstreetbob06
Dec 15, 2014 08:59 AM
Schwanz583
Feb 15, 2013 08:08 AM
snakeyes
May 15, 2011 06:59 PM
Matt115
Mar 31, 2006 04:13 PM
