Rocker c/ Breakout conversion
Old Jan 8, 2015 | 07:54 AM
  #91
shrini23's Avatar
shrini23
so the rocker front end is 49mm narrow to mid glide IMO since ya'll went to the breakout rims did you had to do the whole front end swap or you kept the same rocker front end
coz IMO the factory rocker rims where 21x2.15 whereas breakout im not sure
Old Jan 8, 2015 | 08:09 AM
  #92
24v's Avatar
24v
You have to swap to Breakout, or aftermarket trees to run the front Breakout wheel on a Rocker.
Old Jan 8, 2015 | 10:02 AM
  #93
Alain's Avatar
Alain
Yeah. You have to go to a wide glide front end. Word of advise, since you have to switch the front end go for raked trees to accommodate the bigger diameter of the front wheel.
Bike rides soooo much better now. Doesn't track at all and it feels solid
Old Jan 9, 2015 | 07:10 AM
  #94
Rumbles's Avatar
Rumbles
OP Great job! I bet you have a lot of Rocker owners thinking I know I would be if I had one...
Old Aug 14, 2015 | 03:45 PM
  #95
ZS1RA's Avatar
ZS1RA
1st Gear
Default Rocker fork Breakout rim
Ignore
Old Aug 18, 2015 | 07:19 AM
  #96
ivanoman's Avatar
ivanoman
Very good job.
I'm thinking to convert my rock into breakout also with his rear fender and sit.
I've not well understood the changes made to adapt the fuel tank.
Can you exaplain me ?
THanks
Old Sep 10, 2016 | 07:50 AM
  #97
Abdo George Najjar's Avatar
Abdo George Najjar
Stage III
Hi Man,
I need your help I Have RockerC 2009 and i bought a breackout rims can you help me with your experience what i have to bring more for i can install the rims properly on my bike
thx for you help
Old Sep 10, 2016 | 08:40 AM
  #98
Rocker B's Avatar
Rocker B
Originally Posted by Abdo George Najjar
Hi Man,
thx for you help
You'll need a wide glide/Breakout or after market triple tree, and a new after market axle if you want to use your forks, or you'll need new forks and a new HD axle.....
Old Sep 13, 2016 | 05:39 AM
  #99
Abdo George Najjar
Stage III
Thx for ur answer do u have the part numbers or if u can help where can i find them
thx
Old Sep 13, 2016 | 10:41 AM
  #100
shrini23's Avatar
shrini23
Hi Man,
thx for you help
Hey one more route you can do is, the latest breakout Pro if you look at it comes with an inverted forks, so probably I will go to a dealer ask them to see if they can provide you that,
Inverted forks looks lot cooler and handles a lot better in braking
