Rocker HHI conversion and wider 23" wheel
Old Apr 18, 2013 | 07:27 PM
MAGGUT's Avatar
MAGGUT
Default Rocker HHI conversion and wider 23" wheel
I am about to receive and install my Rocker HHI wideglide trees and conversion. I will also be installing a 23" x 3.5" wheel. I have asked that the wheel come with a wideglide hub instead of the standard Rocker size hub. Should this work fine? Is there anything else I should know about spacing the wheel and rotor correctly?
Old Apr 18, 2013 | 10:18 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I would think you will need wide glide spacers for the wide glide wheel and wide glide trees.
Old Apr 20, 2013 | 10:13 AM
MAGGUT's Avatar
MAGGUT
Thanks Hogpro. I talked to Glen this week and have decided I will be buying the wheels from you. You've definitely got the best pricing around, and seem to be pretty easy to deal with. Can I have you do a little research to confirm what I'll need? My HHI trees should be here in 1 week and I can help you out with any measurements you may need.
CyGlide
Dec 27, 2016 08:52 AM
Rollinburnout
Sep 7, 2014 04:29 AM
Wynchester
Wheels/Tires
Jul 3, 2014 07:15 AM
Psycho Dave
Feb 7, 2012 03:08 AM
j33ptj
Sep 1, 2008 06:29 AM
