TSM Experiment
Old Apr 27, 2013 | 07:52 AM
olongapo1's Avatar
olongapo1
Default TSM Experiment
While having the rear assembly off of an 08 Deluxe, a couple bro's and I decided to perform an experiment. We always wondered what would happen if the Turn Signal Module TSM failed while one the road, how would the bike react. Would the system go into "Limp Mode" and allow you to get home. The answer is No.
(1) We unplugged the TSM.
(2) Turned the ignition switch to the "On" position. The ECM went through its diagnostic mode and displayed a warning indicator light on the speedometer. This was expected.
(3) Switched the run/stop handlebar switch to the Run position. No change to the speedometer warning light. Expected.
(4) Engaged the start switch. Nothing. The starter would not engage and the bike would not turn over.
Summery: If the TSM completely malfunctions and the ECM does not receive the proper signal from it, the bike will not run.
Another item I'll carry a spare of on long trips.
Old Apr 27, 2013 | 08:04 AM
tbonetony06's Avatar
tbonetony06
Interesting, and at the risk of showing my ignorance where is this TCM located and what tools are required to change it out?
Old Apr 27, 2013 | 08:55 AM
cwsharp's Avatar
cwsharp
I believe it is behind the plastic section of your rear fender between it and the battery compartment.
Old Apr 27, 2013 | 10:50 AM
knightenforcer's Avatar
knightenforcer
The TSM or TSSM (if U have alarm option), is located behind the battery box and forward of the swingarm.
Old Apr 27, 2013 | 11:44 AM
FroggyFatBoy's Avatar
FroggyFatBoy
if it only shuts down the starter engagement and not the whole fuel system, with the ign on, the starter should work with a jumper wire to the starter solenoid terminal.
gaspasser
Aug 2, 2020 03:41 PM
dolg
Jun 29, 2015 02:56 AM
zeus33
Mar 10, 2014 04:57 PM
Getyurmotorunnin
Oct 26, 2011 12:17 AM
1coolride
Jan 19, 2010 09:44 PM
