Please help!
Old Apr 28, 2013 | 12:37 PM
Mmarm300's Avatar
Mmarm300
Default Please help!
I have a 95 softail and got the newer style bullet turn signals to replace the giant stock ones. I've wired many a bike and can't figure this out for the life of me. In fact ive rewired the entire bike, and this is the last mystery. Here is the problem:
New front bullett signals have 3 wires. Black (ground?)purple (turn?)and blue (running?) Stock setup only has 2 wires. I'm guessing this is what these are from all my research. One would figure if you don't use the blue (running?) and wire black and purple up,I should be ok. When I wire it this way, all 4 turn signals are on all the time. They do blink when I hit the right or left turn button but they are always on. Why is this happening. Do I have the wiring wrong? The stock turn signals are only 2 wire. The kit I bought has rear signals that are only two wires (black and purple) no problem, plug and play. As I mentioned above, the fronts are three wires. I do not want them to run as running lights.
Please help, I'm about to just ditch them all together which will only end up in traffic tickets!
Old Apr 28, 2013 | 12:39 PM
soft 02's Avatar
soft 02
Stock set up might not have had running lights or it is body ground.
Old Apr 28, 2013 | 01:07 PM
Mmarm300's Avatar
Mmarm300
Bike never had running lights rears work fine, so can't be a ground issue
Reckless Kelly
Mar 12, 2013 09:22 PM
codykucich
Jun 30, 2012 12:15 PM
Rdizzy
Mar 24, 2011 03:31 PM
wiliulfo1
Dec 3, 2009 11:23 AM
ottodoggy
Apr 20, 2007 02:43 AM
