fattenin up the fatboy
Old May 2, 2013 | 02:24 PM
fatusboyus's Avatar
fatusboyus
Default fattenin up the fatboy
well I bit the bullet and am in the process of putting on a wide tire kit on my 06 fatboy...it came with a wussy 130 rear tire, so that has to change!!!
going to post pics as I do it this weekend...I got a "jaybrake" wide tire kit. With this kit you can use a stock 07-09 17" rear wheel that uses a 3/4" axle, and they give you a new Harley brand 20mm rear pulley with bolts and spacers for your stock struts
here's the link:
http://www.jbrake.com/wide_tire_kit.html
here's before
here's my 07 fatboy rear wheel with the new 200/50-17 metzeler me880 mounted (looks like a freakin monster compared to the wussy 130):
my new rear fender from the kit painted to match my tank/front fender from local body shop (its alittle dusty):
i'll post more pics this weekend as I can get em...wish me luck
Old May 2, 2013 | 03:35 PM
KumaRide's Avatar
KumaRide
That is a monster tire! My 06 had a 150 tire originally. I added a 4.25" rim and a 160 tire, looks better now. But, not a monster tire!! lol
Old May 2, 2013 | 04:37 PM
fatusboyus's Avatar
fatusboyus
yeah I couldn't believe how big that 200/50-17 looks mounted on that wheel.....toughest part of the job is gonna be taking the inner primary off, just b/c I've never done it before
but I aint "skeered"
Old May 2, 2013 | 04:43 PM
FroggyFatBoy's Avatar
FroggyFatBoy
why do you have to take the inner primary off ?
Old May 2, 2013 | 04:53 PM
Benway's Avatar
Benway
Gonna be sweet! What are you doing for new fender struts?
Old May 2, 2013 | 05:28 PM
QC's Avatar
QC
Gonna look sweet!
Old May 2, 2013 | 08:44 PM
fatusboyus's Avatar
fatusboyus
you have to change your belt to the newer 20mm wide one...have to also take out swingarm axle and drop left side spacer to switch belts
Old May 2, 2013 | 08:45 PM
fatusboyus's Avatar
fatusboyus
with this set up you reuse your stock ones, they just use spacers in the kit
Old May 2, 2013 | 08:50 PM
fatusboyus's Avatar
fatusboyus
worked on it some tonight....got the outer primary off, the inner primary off, stock wheel and fender out and of course fluid drained from primary
inner primary off:
Old May 2, 2013 | 08:52 PM
AdrianVall's Avatar
AdrianVall
Its really not bad at all.. just be VERY VERY careful when undoing bolts. I snapped an inner primary bolt trying to get it out on my last Dyna. REALLY shitty feeling.. LOL! But its not bad.. just be careful and take your time.
