Doing cams on 06 heritage..........
Old May 17, 2013 | 01:01 PM
Memo7070's Avatar
Memo7070
Default Doing cams on 06 heritage..........
Good Day all, I have a few questions about this task in hand. What are the cams gunna do to the bikes performance and what else will it do?(cool it down, use more gas...???)I currently have a carburator in it and not EFI. I am puting in SE204 cams, adjustable pushrods, new cam plate, gaskets, so on and so on. Any information will help me better understand the cam theory besides more torque. It is an 06 Heritage. Thanks again.
Memo
Old May 17, 2013 | 02:47 PM
KumaRide's Avatar
KumaRide
Installed cams in my 06. imo 204's in an 88" is not the beast choice. Maybe with a 4* advance key? Adding the 2n1 provided a nice sop bump. Had vh bss and the 2n1 was a very noticeable improvement.
Old May 17, 2013 | 02:57 PM
TheTroupe's Avatar
TheTroupe
Everyone has, and is entitled to their opinion. IMO the 204's in an 88 with a 2:1 exhaust is a great combination. Check out the Dyno thread at the top.
Old May 17, 2013 | 03:02 PM
Memo7070's Avatar
Memo7070
I have the samson cholo's (39's baffeled) and the se stage one on it already.
Old May 17, 2013 | 03:14 PM
TheTroupe's Avatar
TheTroupe
With a carb and those pipes, the SE204s are going to give you a great throaty idle sound, good middle RPM power and a reasonable peak horse power increase.
Find a good carb guy and get that puppy jetted in right and you'll have very nice ride.
Old May 17, 2013 | 03:33 PM
Memo7070's Avatar
Memo7070
Thank you for the info and definitly am going to rejet.
Old May 17, 2013 | 04:57 PM
KumaRide's Avatar
KumaRide
Agreed, "middle RPM" and upper hp. Your low end tq will be soft. Everyone knows tq is what moves these bikes. And the largest/Peak numbers dont mean squat. Its the area under the curve that matters. And duals also loose low end tq. Their is a reason why even stock pipes have a cross over pipe. So, duals combined with 204's is gonna be soft in the low to mid...
Checkout the bigboyzheadporting.com calculator and see which cams provide the most compression.
Old May 17, 2013 | 07:05 PM
TheTroupe's Avatar
TheTroupe
No argument about the 204's being "Soft" on the low end compared to 2:1 pipes. But the original poster like his long true dual pipe...
Check out my numbers to see what low end torque you can get form 204s.
https://www.hdforums.com/forum/9756248-post672.html
Old May 17, 2013 | 07:20 PM
tbonetony06's Avatar
tbonetony06
This is a subject much like an Oil thread. You will get many differing opinions. I have the SE 211' in but I also have more motor and head work so I don't know how that helps you. I do know this, my bike comes off the line like rapped ape. I also know this too, I'm not too concerned about that anymore either. It's why going to the 39"s cholos doesn't bother me if I lose a tad after having this Python 2 into 1 pipe. I guess if it turned out to be a complete dog than I would have to reconsider but I am told with what I have I shouldn't lose much, if anything. I'm an "Old Fart" now and I'm into just cruising. I do think that no matter what you go with, rejet your bike on a Dyno tune and get every once out of it it is designed to give you. IMHO, a Dyno tuned bike is much healthier, performs at it's peak and runs cooler. Good luck and let us know how it turns out for you.
robertg
Touring Parts
Nov 5, 2015 08:27 PM
ExtremeBaggers
May 19, 2013 06:37 PM
randybullet
Oct 20, 2012 05:24 PM
AZRenegade
Mar 20, 2012 08:28 PM
abby1408
Dec 10, 2006 11:16 AM
