Monster Build... Rockers?
Old May 23, 2013 | 07:58 AM
chefalan86's Avatar
chefalan86
6th Gear
Default Monster Build... Rockers?
Help! My wrencher friend is just finishing a 114 build with my 2002 fat boy. I am being told that there is a lot of noise coming from the rocker box and now may be faced with rocker work. Cams and head work were done to match 114, nothing but the case boring and crank weld were also done. Cams are big. What direction should I be headed with Rockers? Any feedback, please?
Old May 23, 2013 | 08:00 AM
soft 02's Avatar
soft 02
Were the valve covers clearenced for the high lift cams assuming you used roller rockers. Hard to say when you dont know the cause of the added noise.
Old May 23, 2013 | 08:23 AM
chefalan86's Avatar
chefalan86
6th Gear
Yes, the heads were all done up. My mechanic said that he hears the noise coming directly from the rockers. I am reading on the other posts that the lifters end play have a roll in some noise. My wrencher friend says that there is something going on for sure with rockers. I have also read that the only time that you need upgraded rockers is when the larger cams come into play.
Old May 23, 2013 | 08:46 AM
chefalan86's Avatar
chefalan86
6th Gear
Actually, excuse me, the valve covers were not clearenced.
TroubledWine
Engine Mechanical Topics
14
Mar 26, 2019 01:53 PM
txphatboy
15
Feb 17, 2016 10:29 AM
txphatboy
Jul 12, 2015 09:43 AM
Bullfrog
Exhaust System Topics
May 24, 2013 10:28 AM
tree88
13
Aug 7, 2008 01:16 PM
