Security pin?
When I bought mine, the guy I bought it from didnt even know such a thing exsisted, never mind change it. I was able to retrieve it and change it. Initially it showed up as 11111.....I guess that is stock from factory?
I respectfully disagree. I did this just last night to confirm the new code I entered was correct. The procedure I outlined will result in the display of the security code with the first digit flashing. You step thru the digits by using the right turn signal button. The left turn signal button is used to set the number and you can watch the number increment as you press it. Remember, the FOB has to be present for this to work so there is no way a thief can just go up to your bike and view the code. And since the FOB has to be married to your security system, other FOBs will not work either.
