Backfire on deceleration
Old Feb 25, 2007 | 12:32 PM
ltford2003's Avatar
ltford2003
Stage II
Default Backfire on deceleration
2003 Heritage, V/H longshots w/Baff, Kuryakyn Hypercharger intake, 95 in. big bore kit, high comp. piston, 203 cam, powercommander installed. When using Map 805-069 Stock ECM slight backfire on deceleration, runs worse when using maps 805-068 stage 1 ECM and 805-092 Stage 2 ECM. Does anyone have the same prolem and or solution other than custom map. Thanks for any help
Ragman
[IMG]local://upfiles/25748/1F3F679A4B8540E79FD8765B363CAFF2.jpg[/IMG]
Old Feb 25, 2007 | 01:23 PM
zoomie67's Avatar
zoomie67
Default RE: Backfire on deceleration
There are a lot of reasons for the pop (backfire) on decel. I had the same probblem on mine. You should find that you can control it by rolling off the throttle instead of chopping it. There are lots of threads in here about this issue, try doing a search or call DynoJet they'll help you get rid of it.
Old Feb 26, 2007 | 03:59 AM
cowboy Harry's Avatar
cowboy Harry
Leak at the exhaust port gasket can make it do that too.[8D]
Old Feb 26, 2007 | 10:49 PM
Soft06's Avatar
Soft06
Like Cowboy Harry said, "The first thing to look for is an exhaust leak".
You can learn to ride it so you roll off the throttle easy to minimize the popping, or have the machine dyno tuned. If you have a "canned map" that you are happy with you can also do some adjusting to your map to rid the popping also. My bike popped big time on decel, but with help from the great people here on the HD Forum I was able to adjust my dyno tuned map in the 0% column so now she just gurgles on decel, weather I roll off hard or fast or slow, no popping.
I ended up with 0's in the 500-1250 RPM range in the 0% column ONLY. I put 15's in the 1500-4000 RPM range. From 4250 RPM on up...all 0's. I changed NOTHING else on the map.
Save the map you like FIRST..then do your changes even starting at say 20 in the desired RPM ranges, then ride it and come down slowly on the numbers...18,,,then 16,,then 14...all just examples mind you, but the point is, when the popping starts again, you know what values to put where.
Hope this has helped,
Ride safe..
Old Feb 27, 2007 | 12:27 AM
italiano's Avatar
italiano
hey would and exhaust leak be obvious?
Old Feb 27, 2007 | 10:33 AM
XTrooper3936's Avatar
XTrooper3936
ORIGINAL: italiano
Yes, you "should" be able to hear a distinctive ticking sound.
Old Feb 27, 2007 | 08:54 PM
italiano's Avatar
italiano
had to ask.i dont hear anything at the motor thanx.
Old Feb 27, 2007 | 09:05 PM
Gutman's Avatar
Gutman
Do what soft06 says. Fixes every time. Put in 20 and leave it. If you do like soft06 say's the bike will not feel like you have shut off the ign switch after chopping the throttle.
Old Feb 27, 2007 | 09:08 PM
Oldtimer of NM's Avatar
Oldtimer of NM
ORIGINAL: italiano
Maybe. Sometimes an exhaust leak will close up under pressure so that it only pulls fresh air in without blowing exhaust out.
Old Feb 28, 2007 | 12:15 PM
ltford2003's Avatar
ltford2003
Stage II
Thanks for all the help on this, I will get to work and try them!!!!
