Pain in the ass mods...
I'm getting ready to wire my bars. I'll let you know how that goes. I'm still naive I guess in thinking its not going to be that difficult.
Bleeding brakes:
Initially I was worried about bleeding the front brake lines but then I heard about "a" way, tried it, and found it worked really easy. Take the top off the master cylinder, then attach a hose to the bleeder valve and pump fluid up from the caliper. Air naturally rises up and is pushed out of the top until the master starts to fill up. Top it off and you are done.
Shocks and Sideplates:
I guess the hardest for me would be a toss up between the shocks and sideplates(or detach kit). I installed a Burnout Cycles lowering kit. The kit was simple. Getting the shocks off and back on again was not. The kit uses a 15/16 nut. I was lucky and had a socket to fit but no combo wrench for the other side. The other shock mounting bolt is really tough to get to. The manual says you need some special torque adapter from Snap-on which costs $50. I had a combo wrench and a hammer so I used that. Must have been a whole tube of red locktite on those bolts.
I've done three different sets of sideplates and/or detach hardware. First one I tried without taking off the wheel. Not fun. Lots of cussing and cutting up of the hands. Second and third attempts I pulled the wheel and they went fast, minus the wheel dis-***/*** time.
The shocks were the hardest because of the clearance issues and not having the right tools. The sideplates were just a PITA because it’s next to impossible to get them on without pulling the rear wheel or dropping the shocks to let the swingarm fall out of the way. And I already said how much fun that was.
Actually I'm pretty glad I made the decision to go with a carbed model after hearing all the horror storys about changing the tank on an EFI. Whew!
It would have to be my chrome swingarm and the low-profile shocks! Just a real butt buster that took a lot of grunting and groaning and being in places whereman was not designed to be! You get twisted up into positions that are not good for my 53 year old back, and of course, like anything on my HD, it was one of those jobs where I needed a minimum of 3 hands!
But now that I think about it...there was the disaster that started out as a chrome front end swap but quickly changed when the 6mm cap screw that holds the lower fork slider on stripped out! But that's another thread...
I love working on my bike, but some of these nuts and bolts are torqued way too tight! JMHO
Good luck and keep wrenching...
Steve
I was going to change out my worn rear break rotor with a wicked chrome one and actually BROKE my Craftsman Torx bit on the last friggin bolt! I had to abort the mission.... I'll try again next time I do a tire change. Stupid Torx Bolts!
The first time I went to change my Primary oil at 1000 miles (Factory tightened) the t27 torx bolts were so tight I rounded two of .... had to cut slots in them and tap them loose with a flat screwdriver!
Every time I come across those dang Torx bolts, I swap 'em out with Stainless Hex. Stupid Torx Bolts!
Mimo.
