Harley Davidson Vented Windsplitter Windshield Part Number 57400159
Old Jul 15, 2013 | 06:14 PM
Falcon195's Avatar
Falcon195
Originally Posted by slove
I added one of these to my 2012 Fat Boy Lo and it fit great. I had a full windshield on it first but I still had some head buffeting. By using this new windshield I can now travel at freeway speeds with minimal buffeting. You do have to open the vent to break up the turbulence coming under the windshield. It works for me
Do you have the aux. light kit installed on your FB low?
I really want to try this windshield but i don't want to install the aux. light kit that I think you need to make this shield fit properly.
It seems someone could come up with a spacer kit to be able to install this shield on FLSTF's and make a couple bucks in the process.
Old Jul 15, 2013 | 09:22 PM
load97's Avatar
load97
To to your local hardware store. I'm sure you'll find something there to fit well enough as a spacer. I just used bronze bushings that I had laying around, but even some 1/8" or 1/4" nipples with the threads cut off would work and look nice.
Old Jul 16, 2013 | 05:45 PM
slove's Avatar
slove
The full size windshield that was on my Fat Boy was for a bike with aux lights the mounting hardware is a little longer and worked just fine with the new windshield. I do not have the aux lighting on my bike. I don't know if the mounting hardware is sold by itself through HD
Old May 6, 2014 | 04:10 PM
nairb6868's Avatar
nairb6868
6th Gear
Question. I have a FB Lo with the auxiliary lights.
I am having a hard time figuring out if the quick release hardware comes with the windsplitter windshield or not. If not, what part # do I need to order?
Thanks.
Old May 6, 2014 | 09:16 PM
load97's Avatar
load97
No it doesn't. Just use quick detach hardware that Harley sells for the regular windshields.
Old Jun 14, 2014 | 10:50 PM
karbunkle1952's Avatar
karbunkle1952
6th Gear
Default How I installed the Windsplitter on 2013 Fatboy Lo
I just installed the Vented Wind Splitter Windshield-57400159 on my 2013 Fatboy Lo.
I did not have the auxiliary fog lamps.
Now Harley did have a fix for the "no fog lamp"
It was called the
Harley FLSTF Bracket Kit for 100th Anniv Windshield 58810-02
Unfortunately the only place to find these are on Ebay as Harley discontinued them. That is where i purchased them.
You will also have to order the upper spacers. Harley still produces those. Spacer (2)5885 comes from your local dealer.
So, to do the job you will need:
1 piece -
1 kit -
1 package -
Spacer (2 pieces) 5885
I bolted everything on per instructions and I was test driving in about 1/2 hour after cleaning everything up.
Old Jun 15, 2014 | 06:16 PM
slove's Avatar
slove
I have this windshield on my Fatboy and I love it. I had a full windshield installed prior and still had head buffeting at highway speed. This new Windsplitter wind shield has greatly reduced the buffeting
Old Aug 10, 2018 | 11:46 AM
ESzanto's Avatar
ESzanto
Stage III
Thanks, karbunkle1952, your suggestion worked perfectly!
I have a 2014 Fat Boy Lo and just bought the Harley-Davidson Wind Splitter Windshield (#57400159) and also do not have the auxiliary lamps.
The p/n for the bracket you talked about is 58270-02, and my local dealership had 3 of them in stock! They didn't have the 5885 spacers, but another local dealership did. It took literally 5 minutes to install.
Thanks again for the helpful post, YOU ROCK!
2014 Fat Boy Lo w/Wind Splitter Windshield
Old Aug 10, 2018 | 12:55 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
You do realize that he posted that 4 years ago, right?
Old Aug 10, 2018 | 01:21 PM
ESzanto's Avatar
ESzanto
Stage III
Yes, I saw it was an old post. I wasn't going to say anything at first, but since it helped me I decided to reply. Incidentally, I found that post a few days ago, and it helped me, so I figured I'd say "thanks" and add the part number for the bracket, in case someone else stumbles on the same old post.
