Installing factory security on a new Fat Boy without factory security
Old Jul 5, 2013 | 09:57 PM
Falcon195's Avatar
Falcon195
Default Installing factory security on a new Fat Boy without factory security
OK so I know you can buy the factory security module $359.95 for a 2012 Fat Boy. Now as far as installation. The module looks like it just plugs in to the receptacle on the bike. But I am sure there is more to it than that.
Does anybody know or has anybody installed the factory security module on their FLSTF and how much extra equipment or labor is required?
Old Jul 6, 2013 | 11:38 PM
mac1911's Avatar
mac1911
It's placement is just forward of the rear fender, under the seat. It must be accessed from the wheel well and must ne programmed by a dealer. I do not believe the bike will start, once it is plugged in, without the re-programming. I had one added to my '08, and it works perfectly.
Old Jul 7, 2013 | 03:23 AM
1004ron's Avatar
1004ron
I bought the HFSM which comes with two button-less fobs, and I bought the small siren, but have yet to install these.
My understanding is that you can Marry the TSSM/HFSM to the bikes ECM and be up and running, but will need to have the dealer marry the two fobs to the HFSM.
File Type: pdf
Old Jul 7, 2013 | 04:08 PM
olongapo1's Avatar
olongapo1
I just replaced my TSSM with a TSM. You must sequence (Marry) the module with the ECM. The attachment provided by 1004ron is correct. Ensure that you have a battery charger connected prior to sequencing. Once you have sequenced the two units, you must then program the security module.
Old Jul 7, 2013 | 04:14 PM
Jackie Paper's Avatar
Jackie Paper
That's mine above shocks with flat long white plug..replaces the signal light TSM with the TSSM. That wire hanging lower is the pigtail for the siren and it clips there. It's not necessary to remove the tire.
stoney05
General Topics/Tech Tips
Feb 26, 2017 09:24 PM
Rubline
Electrical/Lighting/Alarm
Mar 16, 2016 05:53 PM
topgunxxx
Dec 22, 2013 03:13 PM
hogster1961
Jan 11, 2012 08:30 AM
jkelley
Jan 28, 2008 07:28 AM
