SE 255 question for the experts?
Old Jul 7, 2013 | 01:08 PM
mauro71's Avatar
mauro71
Default SE 255 question for the experts?
in addition to the cams I must to change the lifters and tappets?
My dealer says yes...is it true or only business?
My bike is a softail deluxe 2012.
Old Jul 7, 2013 | 03:58 PM
olongapo1's Avatar
olongapo1
First off, "Tappets" is an old term for Lifters so lets discard that word. A roller on the bottom of each lifter is in constant contact with a cam lobe and a wear pattern is formed between the two. Normally when replacing any cam, new lifters are recommended and any High End Performance shop would always install new lifters with a cam swap. In your case however, with a relatively new bike and what I assume would be low mileage you might be able to reuse the stock lifters. If I were building your engine, I would not be able to make that decision until after the existing cam and lifters were remove and inspected. Personally, I would match new lifters with any new cam.
Additionally, I recommend that you also consider installing Adjustable Push Rods. The installation of adjustable push rods prevents the need to remove the Tank, Rocker Boxes, and Valve Rockers. This would save hours of labor cost and make any future cam service easier.
Old Jul 7, 2013 | 04:16 PM
mauro71's Avatar
mauro71
Thanks a lot for your suggestion.
Old Jul 7, 2013 | 07:13 PM
tbonetony06's Avatar
tbonetony06
Is it a stock motor? Thats all you're doing is cams, nothing else? Is there stock pipes and intake? May I ask why SE255's, especially if everything else is stock? I also agree, no way to know until they are inspected. Me? I would go new on new unless you have like 1k miles on the bike.
Old Jul 8, 2013 | 03:57 AM
mauro71's Avatar
mauro71
Bike has stage 1 ( v&h true duals, big sucker, conversion from EFI to carb CV rejetted with screamin eagle kit). The bike has 7000 kilometers.
Old Jul 8, 2013 | 04:55 AM
oct1949's Avatar
oct1949
I've read and heard that a bike with 15-20K should have new lifters installed at cam change.
Some Wrench's I've talked to say a bike that has 15K and some have said up to 20k is the point of needing new ones.
Did my cams at 16k and Yes I went ahead and installed new lifters. But didn't have to.
New Torrington cam bearings for sure.
There are a bunch of other cams for a Lux I'd pick over the 255's.. the 255's are made for Heavy Touring bikes that's loaded up and ridden 2 up and have High CCP that can lead to pinging.
The 255's have good TQ in the 1800 to 4k rpm range but fall off quickly after 4K.
If U ride solo mostly, the 204's would be a better pick IMO if U stay with SE stuff.
If U branch out to other cams,, well then theirs a bunch of choices, Pending on Ur riding style.
Old Jul 8, 2013 | 06:45 AM
mauro71's Avatar
mauro71
I think that cams SE 255 are the best solution for me. I need TQ in low rpm range.
Old Jul 8, 2013 | 08:06 AM
tbonetony06
I have 211's and I have more than enough torque. I think my bike would work too hard at highway speeds with the 255"s in it and theres more than a stage 1 involved.
Old Jul 8, 2013 | 08:32 AM
magnum629c's Avatar
magnum629c
Woods 222.... Don't waste time on 255s the 222 is all low end
Old Jul 8, 2013 | 08:33 AM
magnum629c's Avatar
magnum629c
If u want gear drive cams I'll sell u a new set of 510 s&s gear drive cams for a 2007 96 or 103 moter cheap.. There new I never used them
