I don't know the why, just trying to help the OP. HD changed the flimsy washer for the thicker washer. There is no tab on the updated washer. I can only assume they increased the torque to compensate for the lack of a positive lock. Never had issues with the new washer, throw a little blue loctite on there if you're worried about it.
Apologize for name calling. After visiting dealer while back and he did not have a clue to the change we been talking about..just seemed sort of 'who knows'. However after doing a little searching on here, seems as usual with Harley, depending on bike there is a lot of different solutions. Also say if owner is having problems, then for dealer to do this.. The following path can give someone the correct choice since there is about 6 or so depending on bike.
I have never had a problem with fall away getting loose. Mine was just set too tight. However now that it is at 1", I will monitor it. Our roads around here are extremely good test tracks.
