glad i do my own maintenance
Old Jul 20, 2013 | 10:03 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Michael knowles
I change my oil every 1000 k all around. Then have dealer change on their maintenance program as a back up.
You can`t be serious.
Old Jul 20, 2013 | 10:04 AM
mag11581's Avatar
mag11581
Originally Posted by VETERAN75
What type or brand of grease are y'all using for the neck. Are you using the Harley grease? Like to have something good that the oils won't separate from the soap and drip. Thanks
i bought the waterproof "green grease". supposed to be ideal for high heat and wet weather use. didn't want grease dripping onto my front tire while riding.
Old Jul 20, 2013 | 10:10 AM
fcsallan's Avatar
fcsallan
That was what I was thinking. The only way this even close to makes any sense is if he only rides under 1K per year. And if that is the case, that is HOG abuse.
Old Jul 20, 2013 | 10:19 AM
FXDWG12's Avatar
FXDWG12
Just be careful mixing stuff like this. You end up lowering the specs of the higher quality "stuff".
Old Jul 20, 2013 | 10:24 AM
FXDWG12's Avatar
FXDWG12
Wish I had your money. I'd throw mine away.
Old Jul 20, 2013 | 01:45 PM
mag11581's Avatar
mag11581
i put in "green grease",an all purpose synthetic.
supposed to be made for wet and high temp conditions.
don't want grease dripping onto my front tire as i'm riding.
Old Jul 20, 2013 | 01:51 PM
mag11581's Avatar
mag11581
what would you consider "higher quality stuff"
i didn't see any grease on the chemical shelf at my local dealer.
i'm pretty much a stickler when it comes to the chemicals i use on the bikes.
my yammy gets yama-lube and yamaha filters and the harley gets h/d oil and h/d filters. i figured if dealer dont bother selling h/d grease, i dont need to bother using it.
Old Jul 20, 2013 | 01:53 PM
1004ron's Avatar
1004ron
That's obviously a typo !
The manufacturer recommends that the first service is at 1K and every 10K thereafter - shorter intervals can do no harm, but wouldn't see any gains such as cooler running or extended life.
If what you meant was you're servicing it every 1K and the dealer every 10K, you're more likely going through drain plugs, and at risk of stripping the drain threads.
Old Jul 20, 2013 | 02:04 PM
Dan89FLSTC's Avatar
Dan89FLSTC
You can get HD brand grease in the tub, and in a tube for a grease gun. Maybe your dealer has it hidden....It is excellent stuff, I have no clue as to what company makes it.
Now that I`m thinking about it, I think it is about time to pull the front end apart and repack the steering head bearings on my Softail (no grease fitting). It needs it about every 10 years or so...
Old Jul 20, 2013 | 02:34 PM
ibfree2855's Avatar
ibfree2855
Default Amityville
i pumped in two full cartridges 6oz and nothing oozed out. took the bike for a ride in 90 degree + heat and nothing leaked.
I can tell you this though, steering is a HELL of a lot easier. almost scary. gotta get used to it.
making right turns from a stop i always had to pull hard on the bars. now they move like butter.
apparently dealer never added any grease and they didn't do the fallaway test.
Really didnt want to spend the almost $500 for the first service where they were supposed to go over everything but i didn't want to have any issues with warranty claims down the road.
next new bike, eff the 1k service. I'll do it myself.
Hey neighbor!!! Lol
