glad i do my own maintenance
Old Jul 19, 2013 | 03:32 PM
mag11581's Avatar
mag11581
Default glad i do my own maintenance
other than the "required" first service at 1k miles, i do my own maintenance
on my 2010 fatboy. changed the oil at 10k in all 3 holes couple weeks ago.
didn't have a grease gun so i skipped the grease. bought one of those mini pistol grip ones today, figured it would be easier to get at the fittings.
first fitting i hit was the one in the neck. it took 2 3oz tubes of grease!
and it STILL wasn't oozing out anywhere! steering is a lot easier to move back and forth( this my first harley, had a metric cruiser before this) i always figured steering was stiff cuz it was a heavier front end.
could i have done any damage to the head bearings in the past 10k miles?
too hot to check the other fittings. over 100 degrees in the garage even with
a/c on full blast.
never wrenched a h/d before. is grease supposed to ooze out like on a car?
Old Jul 19, 2013 | 03:52 PM
newoldschool's Avatar
newoldschool
grease shouldn't ooze out like a ball joint or tie rod end.
I usually hit the neck with about 3-5 pumps of the grease gun every oil change.
Old Jul 19, 2013 | 05:28 PM
QC's Avatar
QC
From what I've seen in here, what you experienced is normal. The factory just packs the bearings and doesn't use the neck zerk. When I have greased mine, I grease until I get some flow out of the bearings.
Old Jul 19, 2013 | 09:20 PM
UT-rckr's Avatar
UT-rckr
Same here. Greased it just like I would any other zerk fitting until grease started to come out. Took about 6-8 oz to get it there. Wiped up the excess and went riding.
Old Jul 19, 2013 | 09:34 PM
yzergod's Avatar
yzergod
Had that with my Deluxe. Don't know if my stem is loose & needs tightened, but be prepared to have it ooze out the bottom as it heats up.
Old Jul 19, 2013 | 10:46 PM
Michael knowles's Avatar
Michael knowles
I change my oil every 1000 k all around. Then have dealer change on their maintenance program as a back up.
Old Jul 20, 2013 | 08:23 AM
mag11581's Avatar
mag11581
i pumped in two full cartridges 6oz and nothing oozed out. took the bike for a ride in 90 degree + heat and nothing leaked.
I can tell you this though, steering is a HELL of a lot easier. almost scary. gotta get used to it.
making right turns from a stop i always had to pull hard on the bars. now they move like butter.
apparently dealer never added any grease and they didn't do the fallaway test.
Really didnt want to spend the almost $500 for the first service where they were supposed to go over everything but i didn't want to have any issues with warranty claims down the road.
next new bike, eff the 1k service. I'll do it myself.
Old Jul 20, 2013 | 08:24 AM
CanuckSlim's Avatar
CanuckSlim
Why is the 1000 mile service "required" by the dealer? I do that as well and my dealer has no issue with it. Actually will be doing it today.
Old Jul 20, 2013 | 08:31 AM
VETERAN75's Avatar
VETERAN75
What type or brand of grease are y'all using for the neck. Are you using the Harley grease? Like to have something good that the oils won't separate from the soap and drip. Thanks
Old Jul 20, 2013 | 09:59 AM
mag11581's Avatar
mag11581
been told by more than one harley owner that warranty would be an issue if the 1k wasn't done by dealer.
as a first time harley owner, i didn't know better.
