HID Headlight
Old Jul 21, 2013 | 10:08 PM
PDodson's Avatar
PDodson
6th Gear
Default HID Headlight
Im thinking of putting a hid headlight on my softail, can anyone tell me what kind of bulb we got in the housing or do i need to get another housing that accepts the right bulb
Old Jul 22, 2013 | 05:38 AM
QC's Avatar
QC
It is an H4 bulb.
Old Jul 22, 2013 | 07:11 AM
Motown Strag's Avatar
Motown Strag
If you want it all in the can you need a 7in lamp or you will need to put your ballast somewhere else and run a longer harness up to the can.
H4 as mentioned but if you get a kit get the new style that does not require an extra hot wire. The kit I got was PnP.
An on/off switch is recommended. When you start the bike the lamp should be off or you may blow the occasional fuse.
There are a couple good threads with links if you search around on here.
Old Jul 22, 2013 | 08:54 PM
PDodson's Avatar
PDodson
6th Gear
im thinking of a place called ddm tuning
Old Jul 22, 2013 | 09:05 PM
Motown Strag
How much? I think mine was about $28 shipped
Old Jul 22, 2013 | 10:35 PM
PDodson's Avatar
PDodson
6th Gear
its like 37.50, with a lifetime warrenty
http://www.ddmtuning.com/Products/DD...rcycle-HID-Kit
Old Jul 23, 2013 | 06:19 AM
Motown Strag
I looked at that kit and I see a lead for a positive and negative hook up so I think its an older style kit. The kit that some of us have used is a full plug and play harness that runs off of the H4 socket with nothing in or out of the lamp housing.
Anyway, if you try one of these post up and let us know how it works for you.
Old Jul 23, 2013 | 10:18 PM
tryus's Avatar
tryus
If you have a 7" headlight, and switch the lamp out for a "E-code" (Europe's version of DOT) lamp for a Jeep CJ, it'll work much much better, the e-code specs are much stricter, and won't scatter the light as much as the stocker. I did this, and cannot exaggerate how great this setup is! You can buy the e-code lamp at www.quadratec.com, about $40 I think.
hellbob37
Aug 18, 2013 03:41 PM
jdsmitty10
Mar 25, 2013 05:35 PM
WideBoy04
Apr 18, 2010 12:20 PM
Prodaytrader
Mar 13, 2010 08:20 AM
richy rich
Dec 3, 2008 09:02 AM
