Oil break down
It's called poor quality control - the basis for lots of junk science. Then again, maybe Fox is doing a science segment?
I thought about it - for 1/2 second. People who believe that would believe putting an STP sticker on their car will make it go faster. I mean think about it - when you buy new oil, the additives that improve the oil are at their peak. does anyone actually believe oil gets better with use?
Apparently, here's why there is a "wear spike" after an oil change:
High detergent levels, and fresh detergents interfere with the proper function of some of the high-pressure wear preventing additives. These anti-wear additives work by depositing in a very thin layer on high-wear parts. The fresh detergents in fresh oil can prevent these additives from depositing properly, or even strip the existing deposits. In other words, they can have a similar effect on deposits we want, as they can have on deposits we don't want.
That raises an obvious question:
Why don't the oil manufacturers just start out with less detergent, or weaker detergents?
Because the oil is formulated to do the best job overall at normal, manufacturer-recommended oil change intervals. If they started out with less detergent, detergent levels would fall too low before the next oil change comes around.
So it's a balancing act, formulated around a certain expected oil change interval, and wear rates can increase either from replacing the oil too late, or too soon.
Even using a full syn I still change the oil between 4k and 5k miles depending on where and how I have been riding.
If I were living in Tx and running a dino oil, I would definitely change it every 3k miles and would probably run a heavier oil (60w) in the hot months. But I prefer running on the safe side and would use a full syn, either Mobil 1 VTwin, or Amsoil, or Redline, 20/50 weight, and change it around 4k miles depending on how it looked or tested out.
Unfortunately, the SAE paper needs to be purchased in order to read it, but the link has a brief descriptive paragraph.
http://papers.sae.org/2003-01-3119/
HD motors have been tested and found that cyl head temps shoot up to around 325 or more as the motor idles. An extended period of idling (10 minutes) could easily produce a measured temp of 375 in the heads and 400 degrees at the plugs. And don't be surprised to see those temps stay up over 300 up to around 40 mph.
Thank you, I stand corrected.
