Overactive fuel overflow
Old Aug 13, 2013 | 10:30 AM
Trak350's Avatar
Trak350
Originally Posted by DDuess
On mine the vent line comes out of the tank and runs down the back bone, crosses to the left and hooks to the vent valve low on the left side on the frame, then there is a short line that points to the ground. The valve is supposed to shut in in the event of a tip over to prevent spill/fire and is attached to a metal tab on the rear of the trans where the swing arm bolt goes through, right in front of the plastic inner fender. I had to replace mine as most of it was broken or missing for some reason.
Thanks, Ill take a look.
From what the rest of you are saying it is somewhat normal when filled up prior to sitting out in the sun. I will also have to check to see if my bike is in that recall. Thanks everyone
usmcdevildog
Exhaust System Topics
Feb 26, 2025 10:20 AM
streg2
Apr 19, 2024 12:52 PM
thelightsaber
Apr 22, 2013 07:01 PM
Harley03joe
Jan 15, 2011 02:18 PM
Nightster 13
Jul 12, 2007 03:07 PM
