Overactive fuel overflow
Old Aug 12, 2013 | 03:00 PM
Trak350's Avatar
Trak350
Default Overactive fuel overflow
Anyone esle have/had this issue? Not sure if its the SoAZ heat, overfilling my tank, both? Filled up over lunch, ate, then as I left I noticed a decent size puddle and trail of fuel under my bike. The smell is what initially caught my attention. This accured for several minutes. Has happened a couple times before but not to this extent. I never had this problem before I had my oil tank pulled, repainted, and re-installed (dealer mishap) but I dont see how that would be connected to this issue...
Old Aug 12, 2013 | 03:36 PM
olskoolblu's Avatar
olskoolblu
Only once. Squeezed it full, then parked on a hill. Not done it since.
Old Aug 12, 2013 | 03:50 PM
QC's Avatar
QC
I've filled mine up and never had the problem here even 100* + heat. Don't know what the oil tank would have to do with it, either.
Old Aug 12, 2013 | 04:20 PM
Trak350's Avatar
Trak350
Yeah it was parked on a flat surface. I squeeze mine full everytime. It almost seems like an over pressurization. I mean it probably spit out a good 1/3 of a quart maybe more..
Old Aug 12, 2013 | 09:09 PM
DDuess's Avatar
DDuess
If you top off the tank, you will get overflow. The possibility that the vapor line was disconnected from the vapor valve while pulling and installing the tank could be possible.
Old Aug 12, 2013 | 11:08 PM
Trak350's Avatar
Trak350
You would have to school me on this. Tell me where to look. To my knowledge there is one line (vent line, which I call the overflow) that runs from the tank to in front of the rear tire.
Old Aug 12, 2013 | 11:16 PM
Misbehaven's Avatar
Misbehaven
If I top my bike off on hot days I get the same thing. If I am going to fill up before parking I don't top off the tank. Gas expands on hot days.
Old Aug 13, 2013 | 05:14 AM
Blk and Chrome's Avatar
Blk and Chrome
I'll fill up just before I ride on hot days and if out in the sun. If you top it off then park it in the sun and heat for an hour or so it will come out the vent.. normal...Just fill and top off after you eat and you will be fine
Old Aug 13, 2013 | 09:28 AM
DDuess's Avatar
DDuess
On mine the vent line comes out of the tank and runs down the back bone, crosses to the left and hooks to the vent valve low on the left side on the frame, then there is a short line that points to the ground. The valve is supposed to shut in in the event of a tip over to prevent spill/fire and is attached to a metal tab on the rear of the trans where the swing arm bolt goes through, right in front of the plastic inner fender. I had to replace mine as most of it was broken or missing for some reason.
Old Aug 13, 2013 | 09:40 AM
badpig173's Avatar
badpig173
theres a recall on softails bc the gas cap leaks.. i got the recall notice for my fatboy.. i gotta bring me crossbones in bc it hasnt been done yet..
