Rocker project
Old Aug 23, 2013 | 04:07 PM
  #71
Rollinburnout's Avatar
Rollinburnout
thanks again Ink. great info! I thought it would be a lot more to it than that but that seems pretty easy. Im sure I will have more questions to come...I always do!
Old Aug 23, 2013 | 05:08 PM
  #72
LaidInk's Avatar
LaidInk
Alright Jo straight up and down center of the axle looks to be right at 13 1/2" from my concrete floor.
No problem happy to help. Any other info feel free to hit me up or trustnobody as I got most of my info from him when I did the 5 degree trees.
Seems my shotgun is sorta fixed... Takes forever to air up (2 mins at least) and it's still spongy and won't get stiff but I've got a ride tomorrow so ill either deal with it or roll rigid like last time.
P.s. still waiting on labriola..
Old Aug 23, 2013 | 05:18 PM
  #73
Hawaii-Five-Jo's Avatar
Hawaii-Five-Jo
Ink did you call JD?
I waited 6 weeks for my labriola
Thanks homie!
Old Aug 23, 2013 | 05:28 PM
  #74
LaidInk's Avatar
LaidInk
Thanks homie!
Not yet, I got the shock back last week but hadn't had time to throw it on until today. Sounded like a solenoid in the shock before because the compressor would change pitch when adjusting height compared to rebound (high pitch raising height but it never would raise and a low pitch adjusting rebound that worked perfectly sucking the swingarm into the bump stop) now I'm thinking it might actually be the compressor... But I'm gonna play with it a bit to see if i can avoid 2 weeks without it
I've been waiting almost 4, I was just hoping to have it before I got the shotgun back on since I was due for fluid changes.
No problem man!
Old Aug 23, 2013 | 06:15 PM
  #75
rockerz's Avatar
rockerz
hey rockerz, any advice on the fender chop? any measurements? Ive looked at a lot of pics here of fender chops and some look good and some are a bit short for me. Also, what size tail light did you go with? I think ive talked myself into the 26" front wheel but I havent checked on the cost of raking it out and whatever else ill have to change with it. I know it cant be cheap!
Tail light is 9" long. The fender length is 19" from upper bolt to end of fender. I welded on a flat piece under the fender to allow the tail light to sit nice & straight as well as cleans up the sharp edge from the cut.
Old Aug 23, 2013 | 11:54 PM
  #76
Rollinburnout
Just wanted to say thanks to everyone here. You guys have helped tremendously! That being said you guys know I have more questions. So I found these wheels and I need some input.
http://www.demonscycle.com/wheels-ri...ide-tires.html
http://www.demonscycle.com/wheels-ri...ngle-disc.html
Talked to them about the 23" and they said they didn't have narrow glide only wide glide and it would work if I changed to a wide glide front. So if I go with the wide glide front end on my bike I assume that'll work. But as you can tell I am learning as I go.
The rear seems to be the correct size but says its for a 1" axle. I'm thinking the rocker has a 3/4" rear axle but I'm really not sure. If so can this be easily changed.
I really hope they will work cause They are the only wheels I have found that I like that wont cost me an arm and a leg.
Then again they may be a big pile of crap for all I know!
Thanks again for all the input.
Old Aug 24, 2013 | 01:56 AM
  #77
Hawaii-Five-Jo
Rollin I heard some horror stories about demon cycles. Just a FYI bro.
Those might be ultima king spokes. Check out jireh cycles(no sure on spelling). But I think they are a supplier.
Again if I wasn't across from the beach I'd have spokes but then again I'm to fat to sit and clean 100 spokes hahahahaha
Old Aug 24, 2013 | 06:26 PM
  #78
m i k e's Avatar
m i k e
ditto on d.cycle heard bad stuff from dem fools
Old Aug 25, 2013 | 02:04 PM
  #79
tkurfurst's Avatar
tkurfurst
1st Gear
I am embarking on a similar adventure. Bought a 2008 Rocker a week ago inspired by the awesomely beautiful customization I saw on this forum by HD100. Can't wait to get started. Good luck on your build!
Old Aug 25, 2013 | 09:09 PM
  #80
Rollinburnout
Tkurfurst....good luck and welcome to the world of I can't find sh*t for my bike!!
Just kidn. It's not too bad!
Thanks guys for givin me a heads up on demon cycles. I'm still up in the air on what size wheel to go with. I really want a 23 but its a lot more parts and Money involved when I could just get a 21 and change nothing. Guess ill just bite the bullet and spend the money for some ride wright wheels. Looked everywhere for something cheaper but I am trying to keep in mind that ya get what ya pay for. I know several of you guys have 21's on your bikes. Any opinions?
I'm really just wanting someone to talk me into buying a 21. Haha.
