Pinched inner tube
Old Aug 19, 2013 | 11:17 PM
Softail HA's Avatar
Softail HA
I called Dunlop directly , the maker of the Harley inner tubes, they were professional they said they would look into it. I am just glad it was not worse ,I was riding on steel before I was able to pull over on the side of the road.
Old Aug 20, 2013 | 08:54 AM
cwsharp's Avatar
cwsharp
I wouldn't jump on Dunlop so quickly...
H.D.'s rims are notorious for rusting... and right around the tire valve is a prime spot. The rust creates spikes that will cut a tube. You have to take all of the rust and burrs off of the rim before installing a new tube and I'm willing to bet that dealers don't take the time to do that.
I eventually bought a new rim from Drag Specialties because I like the profile better and it is easier to change the tire than with H.D.'s square channel design (which does look better, however). I got s.s. spokes and then I sealed the nipples on the inside with silicone. Next tire, the rim still looked like new. Unfortunately, if you have to re-true a rim you have to reseal the nipples.
C#
Old Aug 20, 2013 | 06:09 PM
Softail HA's Avatar
Softail HA
C#
It is a 2011 I actually went into the shop to take a look at the wheel myself the inside of the rim was flawless ,but I too thought that was the problem. The tube is actually cut following the circular line of the silver dollar sized reinforcement that surrounds the valve stem, on both tubes ,what makes it even stranger is the first tube that failed was my original tube,which was put back in after i had a new tire put on,about 4weeks ago.
Old Aug 21, 2013 | 11:11 AM
Softail HA's Avatar
Softail HA
Just received a call back from an engineer at Dunlop, very nice fellow, he says the only way this could have happened to two tubes is they have used to much lubrication when they mounted the tire, the tire is shifting, and pulling on the tube as it goes. This does make sense since the reinforcement around the valve stem looks like it is trying to be pulled out. He told me to chalk the tire and rim keep an eye for movement.
Old Aug 22, 2013 | 09:09 AM
SprungDave's Avatar
SprungDave
"Pinched tubes" are caused by only two things: installation error and massive under-inflation.
The rim liner should always be replaced when the new tube is replaced (usually when the tire is replaced). The rim liner protects the tube from contacting the inner part of the spoke nipples, so they do not contact the tube. The innertube is an old, tried and true technology. Hard to mess it up unless the installer is careless.
If there is a tube defect, well, it happens. rare, but it does happen. The tube valve is fastened to the rim, so I am at a loss to understand how an inflated tube with 35-40 lbs of pressure inside a rubber tire shifts so much as to rip out the valve can be torn from the tube, regardless of the "lubrication" used (which is soapy water - that evaporates).
But if it has happened twice to you, I suspect the problem is the installer.
Ride safe!
Old Aug 22, 2013 | 11:05 AM
Softail HA's Avatar
Softail HA
Dunlop offered me a new tire credit which I am happy with , I still want a proper response from the local Harley Dealer, as to how this happened , but as usual they say it is not there fault, although it only happened after they installed the new tire.
Sprung Dave what could they have used that could have allowed the tire to shift, I believe they told me they use( Baby powder)
Old Aug 22, 2013 | 11:55 AM
Ramboamt's Avatar
Ramboamt
Tire shift can be caused by under inflation and aggressive acceleration when under inflated.
Also, to much baby powder can act as a lubricant around the edge of the wheel that the tire contacts letting it slip even at the proper inflation pressure.
The baby powder is used on the tube only not the wheel assy.
Soapy water is the proper lubricant to mount the tire to the wheel as it evaporates after awhile.
Old Aug 22, 2013 | 02:37 PM
oct1949's Avatar
oct1949
After reading this, I agree with what Ur answer from LOP was. Usually a pinched tube will not hold air for long before going down. Urs lasted several weeks.
Maybe the dealer is using some kind of lube instead of soapy water to install and its letting Ur tires slip as they (LOP's) said.
I'd check to see how the dealer installed them.
Old Aug 22, 2013 | 02:47 PM
Skeezmachine's Avatar
Skeezmachine
Guess I sortta got lucky with my incident. The first and only front tire chage I have done on my Crossbones resulted in an unexplained flat front about a week later. I was able to ride it home, stopping at the dealership that replaced the tire on the way to have it checked. They aired it up and said it was holding, however I barley managed to pull into my garage before it all went completely flat. I removed the front wheel and took it to the dealer on the way to work the next day. They had the tech check it out and I was told that the tube had been pinched during installation. The replaced it and set everything right without any charge and even offered me a $10 voucher as an apology.
Old Aug 22, 2013 | 02:56 PM
checkers's Avatar
checkers
Originally Posted by dbb
Worrying me now. I have a road trip coming up, just installed a new tube in the bike today, but I did it myself and made extra sure not to pinch it. I always use a lot of baby powder on the tube when mounting it, and lube up the edge of the tire to help seat the bead.
Haven't ever had a pinched tube, but makes me think.
I had a new Metzeler 888 I supplied the dealer to put on last month. He suggested a Parts Unlimited tube he would sell me. I wanted to buy the tube from the dealer, in case it failed I could hold dealer responsible. This is on my Heritage. I put on 1000 miles before I left on vacation last week. I put on an additional 2000 miles with my wife and luggage, no failure. It may be a Dunlop issue, but likely an install issue. Mine was installed by a line tech, the "the helper" tech
