battery
Old Aug 22, 2013 | 01:28 PM
billytwobags's Avatar
billytwobags
Default battery
If i take my bike off the road and the battery gos flat will my alarm go off ? I am moving the bike to a friends garage as i work away and dont want anything going down . Thanks folks
Old Aug 22, 2013 | 01:32 PM
oct1949's Avatar
oct1949
It'd be better to remove Ur battery from the bike and/or put it on a maintenance charger, that will also remove any chance of alarm issues.
Old Aug 22, 2013 | 02:24 PM
08Nighttrain's Avatar
08Nighttrain
Or buy a trickle charger and keep battery fresh so that you dont have to replace it later on.
Wasnt sure how a battery could go flat? Guess if you got a nail in it
Old Aug 22, 2013 | 04:13 PM
billytwobags
If i disconect the battery will alarm kick in thinking that someone is disarming it ? And no nails soz a Limey saying for a discharged battery
Old Aug 22, 2013 | 04:15 PM
08Nighttrain
If you disconnect the battery the alarm will not kick in.
Old Aug 22, 2013 | 04:54 PM
jeffreydsilver's Avatar
jeffreydsilver
Default Check Your Owners Manual
Uh - yes it will! (at least it does on my 09 Road King) I speak from experience! You'll need to check your owners manual but I believe that the correct procedure would be to turn the bike to the on position and then pull the main fuse BEFORE disconnecting the battery.
Old Aug 22, 2013 | 05:07 PM
billytwobags
Thank you i thought even HD would not be that daft to allow anyone to just disconnect the battery thought they must have a back up i will check owner manual when i get home cheers
Derf_
Oct 9, 2019 05:36 PM
BadX
Dec 31, 2017 04:52 PM
Buff58
Nov 29, 2012 03:39 AM
rookiedan
Sep 22, 2008 10:51 AM
