Speedometer stopped working?
Old Sep 16, 2013 | 06:02 PM
Fatboy Ford's Avatar
Fatboy Ford
Stage III
Default Speedometer stopped working?
Hey guys and gals,
Been looking at this forum for awhile and this is my first post.
Searched around but did not find a thread that quite resembled my problem so here I go.
My 2006 fatboy speedo is not working, About 2 months ago it started bouncing around a little then nothing, it stays at zero. The bike starts and runs perfect, signal cancelation works, and the odometer is still working.
Any ideas out there?
Doug
Old Sep 16, 2013 | 07:23 PM
jreichart's Avatar
jreichart
Since everything else is working, then the ECM is most likely still receiving a good signal from the speed sensor. I would check all the connections at the back of the speedo then trace back the wiring to the ECM and make sure all those connections are good as well. Look for any chaffed wires and check that all the grounds are solid. Might be able to remove the speedo and have the dealer or an Indy check it to see if its functional. Good luck, and be sure to post when you've got it fixed so the thread gets some closure!
Old Sep 16, 2013 | 07:30 PM
scasey's Avatar
scasey
Mine did the exact same thing a year ago ended up having to buy a new speedo.
Wasn't speed sensor, or the battery or the numerous other suggestions I got on the forms it was a bad speedo. Not cheap for a new one
Old Sep 16, 2013 | 07:47 PM
Fatboy Ford
Stage III
Thanks,
I'm going out of town till next week so after that I will check all the wiring.
Really just wanted some collaboration that it wasn't the speed sensor since everything else was working.
Old Sep 17, 2013 | 05:37 AM
cwsharp's Avatar
cwsharp
Originally Posted by Fatboy Ford
Thanks,
Stock ECM?
Borrow a speedo from a buddy with the same era and series of bike and make sure that it's the speedo before you buy one.
Old Sep 17, 2013 | 05:43 AM
Jackie Paper's Avatar
Jackie Paper
Check the connections. My tac does the same thing. Hasn't died yet however. There is a little motor in there I think.
Old Nov 10, 2013 | 05:35 PM
Fatboy Ford
Stage III
Sorry it took so long but the bike was running so I waited till the weather turned cold on me to resolve this issue.
I took the bike into the local dealer and they tested it on the bike and the speedo was definitely bad. Only problem was the $300 plus price tag.
Looked around and found a used one for $75 + shipping. Installed tonight and she works great.
Now my bike has 24k miles on it and the new (used) odometer has 18K.
Is there anyway to change the odometer reading???
Thanks,
Doug
Old Nov 10, 2013 | 06:48 PM
oct1949's Avatar
oct1949
Think the dealer or MoCo resets the ones they sell ..
SOOO.. .. maybe that's how so many bikes only have 7k on them
Also if U don't get an answer n here, Ur dealer might help ya.
Old Nov 11, 2013 | 05:25 AM
cwsharp's Avatar
cwsharp
Thanks,
Doug
The dealer is the only person that can do it for a stock ECM. I don't know about others. I'm thinking the speedo used to have to go to the factory... but I'm not sure. Most states its illegal to fiddle with Odometer mileage so you probably have to have it done.
venomv8
Electrical/Lighting/Alarm
Jun 15, 2014 07:10 AM
19JMan70
Apr 11, 2014 06:03 PM
drs0413
11
May 12, 2012 01:01 PM
jcboof
Mar 19, 2008 05:57 PM
rking2000
Oct 14, 2007 05:44 PM
