Electrical Problem
Old Aug 26, 2005 | 04:07 PM
glpionke's Avatar
glpionke
6th Gear
Default Electrical Problem
I have a 2001 Softtail Standard. I am having a problem with me tail light always going out and noe my horn is not working. I have checked the fuses and none are blown. I can replace the bulb and it works for a little while, but then goes out again. I have looked at the scamtic and the horn and light don't appear to be inter connected. Has anyone had simular problem or suggestions as to what to look for.
Thanks
Old Aug 27, 2005 | 09:18 AM
LUV2RIDE's Avatar
LUV2RIDE
Default RE: Electrical Problem
I had a ele prob like that in my 98 ..took it to the dealer and they found a bad ground
Old Aug 27, 2005 | 10:36 AM
HDF Tech's Avatar
HDF Tech
You can do a check to see if it is a bad ground by using a piece of wire and connect one end to the NEG of the battery and touching the other end to the horn or light base to see if it works then. If it does work then ,you have a bad ground in that system. Then comes the fun of finding it.
Razo
Aug 17, 2018 07:05 PM
Job2
Electrical/Lighting/Alarm
11
Sep 11, 2015 01:57 PM
Billf
Sep 6, 2010 06:12 PM
Worped
Mar 24, 2010 12:24 PM
jsbridgew
May 26, 2009 09:11 AM
