Shift lever replacement..
Old Oct 10, 2013 | 07:42 AM
deluxe's Avatar
deluxe
Default Shift lever replacement..
So after much seaching online can anyone help me on this request...
I was going to replace my worn Shift lever (the splined one the heel/toe levers attach to), but was appalled by the HD price tag. So, thought I'd look into aftermarket ones. None!
Has anyone ever found or used an aftermarket lever or are we stuck with the dull HD one.
Bike is an 06 Deluxe..
Any help is apperciated in advance,
Thanks
Rob
Old Oct 10, 2013 | 09:51 AM
QC's Avatar
QC
Here's one set
http://www.google.com/url?sa=t&rct=j...U8cchZ1dtYgZvQ
Old Oct 10, 2013 | 10:49 AM
oct1949's Avatar
oct1949
Old Oct 10, 2013 | 11:10 AM
deluxe's Avatar
deluxe
Thanks guys,
Its not the heel/ toe bits I'm after.
The part I'm after is the splined lever rod that these shifter arms slide on to. This then bolts to the gear shift linkage.
Hope that makes sense.
Rob
Old Oct 10, 2013 | 11:44 AM
FreddyP's Avatar
FreddyP
Are you talking about HD PN 33668-90C? Go to Ronnie's harley OEM parts finder and verify. That might help others provide alternatives if that's the part you are talking about.
http://www.shopronniesharleydavidson...partfinder.htm
Hope this helps.
Old Oct 10, 2013 | 01:45 PM
deluxe's Avatar
deluxe
Thats the one, Well done FreddyP.
Anyone know of an aftermarket one of these? There seems to be aftermarket bits for everything else.
Thanks.
Old Oct 11, 2013 | 04:25 AM
deluxe's Avatar
deluxe
Thanks.
Old Oct 14, 2013 | 07:57 AM
deluxe's Avatar
deluxe
Finally found a possible (see link)
http://www.ridersdiscount.com/Bikers.../dp/B00DHJD6UM
Never seen the 'bikers choice' stuff before. Are they any good? How do they compare against the OEM stuff?
I could buy 4 of these for the price HD want for just one! If there no good though...
Any help guys will go along way.
Thanks,
Rob
Old Mar 29, 2020 | 04:47 AM
staged67gspwr's Avatar
staged67gspwr
need help removing the shifter lever does anyone know If the kickstand bracket has to be removed?any help appreciated
tenn.vol.
Aug 26, 2016 07:02 AM
lolife99
2014-2024 Touring Models
Jul 5, 2016 09:49 PM
DaSham58
Dec 19, 2008 01:34 PM
Swampman
Jul 29, 2008 01:43 PM
vet767
Apr 30, 2008 02:41 PM
