Brake light
Old Oct 12, 2013 | 09:41 AM
Joanrava's Avatar
Joanrava
6th Gear
Default Brake light
My brake light works only with the bar level but not with the foot pedal, any advice?
Old Oct 12, 2013 | 10:05 AM
Santo's Avatar
Santo
Check fuses, check the two connections on the rear brake switch making sure they are on right (you can even test them with a 12volt meter to see if you have power) always check the obvious first. The switch is located on the right side of the bike against the frame near the exhaust. Hope this helps.
Old Oct 12, 2013 | 11:01 AM
Joanrava's Avatar
Joanrava
6th Gear
Thank you very much.
Old Oct 12, 2013 | 11:05 AM
chester1957's Avatar
chester1957
I would check power at the orange wire I believe to the rear switch as posted above. If you have power, you'll need to replace switch.
thumper89
May 2, 2015 03:19 AM
MachU
May 30, 2014 11:50 AM
twistedbluesteel
Jul 23, 2012 01:56 PM
brwdarr
EVO
Sep 14, 2011 07:01 PM
hBob
Sep 14, 2009 06:36 AM
