Brake light activation by rear brake pedal
Old Jul 19, 2012 | 08:34 PM
twistedbluesteel's Avatar
twistedbluesteel
Stage II
Default Brake light activation by rear brake pedal
'00 Sportster. The brake light works when using the front brake. It doesn't when depressing the rear brake. I've tested the continuity for the brake light pressure switch -- it's good. Ohms are near zero when the pedal is depressed. The brake light comes on when I touch a wire to both terminals on the switch. But pressing the pedal will not activate the brake light. There is power to the switch via the o/w wire. There is ground continuity with the other terminal (the r/y wire).
Any ideas?
Old Jul 23, 2012 | 01:00 PM
twistedbluesteel
Stage II
A circuit, such as the brake switch, can show continuity with the slightest contact; but not enough contact to carry the current required to do the job -- in this case, lighting a light bulb. The switch was faulty.
I replaced the switch and the circuit works fine.
Hope this will help anyone who has a similar problem.
TBS
Old Jul 23, 2012 | 01:56 PM
Punisherdave's Avatar
Punisherdave
Just replaced my front brake switch same issue. If it works when you jump the wires together then you have a bad switch
MachU
May 30, 2014 11:50 AM
CSM Sandoval
Dec 19, 2012 02:56 PM
Deelux
Jul 30, 2012 08:40 PM
frenchbiker
Oct 26, 2011 05:25 PM
tidefan60
Apr 23, 2010 01:45 AM
