Home made fangs
Old Oct 17, 2013 | 08:16 PM
gchristopher9's Avatar
gchristopher9
Default Home made fangs
I'm going to make a set of fangs to use on my deluxe to prolong my riding season as much as possible. Would rather not drop $100 on something I'll only use for a few weeks. Also going to make them out of polycarbonate so they don't stand out as much. Was hoping someone could take some measurements of their softail fangs so I have a starting point. Looking for overall length and width at widest point. Any help is greatly appreciated. I'll post pics when I'm through.
Old Oct 21, 2013 | 10:47 AM
gchristopher9
Bump for some help. Would like to start working on these later today.
Old Oct 21, 2013 | 11:48 AM
Shep68's Avatar
Shep68
15.5" length by 4" width at it's widest point (up top). They taper down to around 2" width as they run down the fork. Good luck.
Old Oct 21, 2013 | 02:55 PM
gchristopher9
Thanks Shep!
Old Oct 21, 2013 | 03:23 PM
Shep68's Avatar
Shep68
No problem. Hope the project works out for you. Those fangs really do cut down on wind buffeting. One of the best bolt on mods I've done to any bike.
Old Oct 21, 2013 | 04:55 PM
KumaRide's Avatar
KumaRide
Just installed fangs a couple weeks ago when temps dropped in the sierras. They do work. Be sure to post what you end up with.
Old Oct 21, 2013 | 08:27 PM
Warren9073's Avatar
Warren9073
My brother made his from the specs he found on the Memphis Shades.
Old Oct 23, 2013 | 09:27 AM
gchristopher9
Warren, any chance you could find out what material and thickness he used?
Old Oct 26, 2013 | 05:22 PM
oct1949's Avatar
oct1949
I am not warren,
But I'd guess its Lexan, cause it looks like he put a bend in to keep them from flexing. Thickness, they look thinner than the shield, so I'd guess again it 1/8'' or no more than 3/16''
Brackets. I have no Idea where or what he used..
These also look shorter than the Hd fangs.
Old Oct 26, 2013 | 08:56 PM
Warren9073's Avatar
Warren9073
3/16" plastic from Home Depot.
The mounts are made from brake line relocates from a 6" ford super duty lift kit.
