200 tire conversion project
Old Oct 28, 2013 | 10:32 AM
  #31
Village Idiot™'s Avatar
Village Idiot™
Originally Posted by gnarlyfox001
I exchanged the one I had. Kinda sucks didn't want to use a stock pulley but the others are way to expensive for my blood.
That's what I found out and even the OEM pulleys are pretty expensive.
Old Oct 28, 2013 | 10:55 AM
  #32
EasternSP's Avatar
EasternSP
Fatbaggers makes a fat tire kit, complete with a wide fender. For the 06 Road Glide the kit includes spacers that go between the motor and primary and the tranny and the primary for the belt clearance. It also includes a swing arm for the added clearance of the wider tire. The installation proceedure requires some tabs be ground down in the wheel area so the tire doesn't rub. I'm sure they would have the hardware that you need to complete your job.
Old Nov 7, 2013 | 08:35 PM
  #33
gnarlyfox001's Avatar
gnarlyfox001
Well received my new pulley and this one is the correct width. Tried to mock this up and the wheel with the pulley installed on the rim will not fit. The factory night train wheel 17x6 will not work with this swap as the assembly is the same width as the swing arm. My swingarm is 10" wide and so is the wheel with the pulley. Unless anyone else has gotten this to work I am gonna have to use a 18x5.5 I am assuming.
Old Nov 8, 2013 | 04:01 PM
  #34
Tom84FXST's Avatar
Tom84FXST
When Harley first came out with the 200 tire on softails, they were constantly changing things. I know that 06 was a one year offset...and they changed it again later...not sure what year. So if you have an 06 wheel you have to have an 06 pulley...if you have an 07 wheel you have to have an 07 pulley. You can use this link to check part numbers to see what you have:http://www.shopronniesharleydavidson...partfinder.htm
Old Nov 8, 2013 | 05:22 PM
  #35
gnarlyfox001
I don't see the part # on my wheel but when I purchased the wheel was told came off of a 09 night train. I also purchased a 09 rear pulley.
Old Nov 8, 2013 | 06:31 PM
  #36
Tom84FXST's Avatar
Tom84FXST
If you look on ronnies parts site...00-05 uses the same swingarm...06 uses a different one...07 uses a different one...and 08 up uses a different one...might email someone selling one on ebay, and ask them how wide it is....might need an 09 swingarm? The aftermarket swingarm I used to put a 200 on mine was over 11" wide inside.
http://www.ebay.com/itm/Harley-David...f2847e&vxp=mtr
Old Nov 8, 2013 | 06:56 PM
  #37
gnarlyfox001
I looked last night for a swing arm but not sure if the ID for the pivot point would be a different size or mounting would be any different. Don't want to get anymore wrong parts. Maybe I could call Ronnies and get the info i need.. Thanks for you help.
Old Nov 9, 2013 | 08:21 AM
  #38
Tom84FXST's Avatar
Tom84FXST
In my experience dealers are no help on telling you what parts will fit non stock applications...if the book says it it fits an 09, they will tell you it will not fit an 04...even if it will. Your next hurdle will be getting the rear pulley lined up with the trans pulley...which will require offset to get the belt properly alined. A "kit" with all the proper parts and instructions, is still your best bet to get a bike that tracts straight going down the road.
http://www.ebay.com/itm/For-Softail-...faae5d&vxp=mtr
Old Nov 10, 2013 | 10:55 AM
  #39
gnarlyfox001
looking into purchasing a 08-09 rear swing arm and not sure if the pivot shaft is the same ID as mine from a 04. I know the rear axle is 25mm and also if the shock mounting is the same. Any info would be greatly appreciated.
Old Nov 14, 2013 | 10:12 AM
  #40
gnarlyfox001
Decided to machine down the pulley and wheel hub. Will be done today and gonna mock up for spacers. Should have updated pics later.
