axle question
Old Oct 21, 2013 | 05:38 PM
see22ds's Avatar
see22ds
Default axle question
Ok so all the research I have done tells me a 99 softail has a 3/4" inch axle...why does mine measure 7/8" in diameter? What am i missing?
Thanks for any help...iit is appreciated
Old Oct 21, 2013 | 05:57 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Softails through 2006 originally came with 3/4 inch axles.
Correction: See Ripsaws post below.
Old Oct 21, 2013 | 07:54 PM
sagebrush1976's Avatar
sagebrush1976
It is indeed 3/4". Are you measuring the right side of the front axle where it sticks out of the lower leg by chance? Their is a shoulder on that side of the axle that is stepped up to approx 7/8".......just a thought.
Old Oct 21, 2013 | 08:04 PM
Jackie Paper's Avatar
Jackie Paper
The 2004 SE Softail Deuce with the dual front brake rotors has the next size 25MM axle which is slightly larger then 7/8 (.875) at .975 I think. That 3/4 on most like Sage says is the area at the bearing ID. 3/4 is what you want since it is the double row opposing thrust bearings that last 100K plus. The larger axles actually run much weaker bearings.
Vt harleydyna2003
Sep 29, 2014 11:40 AM
Vt harleydyna2003
Sep 28, 2014 05:48 PM
FL DEUCE
Feb 15, 2013 09:11 AM
HRK123
Aug 4, 2012 01:35 PM
8541hog
Apr 28, 2010 10:22 AM
