Squealing noise from left side
Old Nov 7, 2013 | 07:27 AM
njmasterplumber's Avatar
njmasterplumber
6th Gear
Default Squealing noise from left side
Having an odd issue and need some help. Have an 02 Heritage with almost 25K on it. When i'm going about 35 to 40 mph I get this squeling type sound that seems to be coming from the left front primary or engine area. If I power up it goes away. Pulling in the clutch while I hear the noise does nothing, the squeal remains. Once I get above 40 to 45 the noise disapears. Any help would be appreaciated. I don't think its the comp sprocket cause it doesn't clunk ot grind at all.
Old Nov 7, 2013 | 07:47 AM
HDmikie's Avatar
HDmikie
Could it be the drive belt? Put the bike up on a lift and run in gear to 35 mph and see if you can pinpoint where the noise is coming from. Maybe have someone help being as the throttle is on the right side.
Old Nov 7, 2013 | 10:05 AM
streeteagle's Avatar
streeteagle
Sounds like it may be primary chain, have tensioner checked.
Old Nov 16, 2013 | 07:34 AM
njmasterplumber
6th Gear
Thanks guys. Even though the noise seemed to be coming from the left front down by the primary it was actually the rear drive belt. A quick shot of silicone spray at the sprockets seemed to have solved the problem. Ridden a few hundred since and no noise. Talk about a easy fix
Old Nov 16, 2013 | 07:46 AM
oct1949's Avatar
oct1949
I wouldn't use silicone spray or any belts lube on the sprockets or face of the belt.
Son had belt squeal on on his 09 NT. The wrench we like the best and does our work at our dealership gave him a little tin with some belt dressing in it and told him to use it sparingly and ONLY use it on the belt edges.
kinda Like the old Bryl-cream ads, a little dab will do Ya.
fwj
Milwaukee Eight (M8)
Aug 3, 2021 04:18 PM
Honda45
Jun 29, 2015 05:09 PM
Abandoned
Aug 18, 2013 02:57 PM
troy.j
Aug 25, 2012 10:58 AM
BLACKTOP GLIDER
Northeast
Apr 23, 2010 08:41 AM
