Need help diagnosing a zzzick noise
Old Aug 24, 2012 | 10:09 AM
troy.j's Avatar
troy.j
Default Need help diagnosing a zzzick noise
I am getting a zzzzick noise when the bike is warm and I let off the throttle or get on the throttle from compression. The more gradual the change is between the two the longer the noise lasts. I also have louder than normal shifts once the bike is warm. I suspected the primary chain, but I have pulled the outer primary and inspected the chain adjuster. I don’t see anything wrong there.
Bike is an 08 ultra with 30k on the clock. Any help would be appreciated.
Old Aug 24, 2012 | 01:01 PM
MadIrish's Avatar
MadIrish
An audio recording of you trying to reproduce this zzzzick noise will be required for further diagnostics....not an audio recording of the actual noise (that would not be helpful!), just you making the noise.
For calibration purposes, a clip of you singing "Karma Chameleon" by Culture Club will also be required.
Old Aug 24, 2012 | 01:07 PM
FutZ's Avatar
FutZ
6th Gear
MadIrish I think you just made my day.
Old Aug 24, 2012 | 04:57 PM
troy.j's Avatar
troy.j
... your knowledge and insight is astounding. i worry you may have stressed something coming up with that one. seek medical assistance immediately!
Old Aug 24, 2012 | 05:03 PM
troy.j's Avatar
troy.j
The sound is a mechanical sound. I thought It may have been the primary chain slapping the inner primary as the chain went slack while transitioning from power on acceleration to coming down on compression, or from compression to on throttle.
Obviously there is no sound while the bike is still or in neutral.
Still looking for assistance.
Old Aug 24, 2012 | 05:10 PM
dawg's Avatar
dawg
Stock comp or SE? The harley chain adjuster isn't the greatest and has been known to make a noisier primary.
Old Aug 24, 2012 | 05:13 PM
troy.j's Avatar
troy.j
stock compensator sprocket.
i disassembled the adjuster and didn't see any badly worn parts. before removing it, the chain had good tension.
i just added mobile 1 to the primary and changed my engine oil. i am waiting for my front tire to get mounted and i will take it for a ride and see if it is still there.
Old Aug 24, 2012 | 05:15 PM
dawg's Avatar
dawg
Your primary would probably like the SE comp and a Hayden M6-BT07 tensioner, just sayin'
Old Aug 24, 2012 | 07:49 PM
troy.j's Avatar
troy.j
thanks, i will keep it in mind.
Old Aug 25, 2012 | 10:58 AM
MadIrish's Avatar
MadIrish
@Troy.j
My post was totally in the spirit of fun and was impossible to resist. One man's zzzik is often another man's zzzIck! If you've ever heard an episode of Car Talk on the radio you'd've got it. Listening to people trying to describe a noise to a mechanic is often hilarious.
RCermak
EVO
Jul 12, 2016 11:21 AM
Abandoned
Aug 18, 2013 02:57 PM
Falcon195
Aug 2, 2013 04:11 PM
troy.j
Aug 27, 2012 03:50 PM
Houndog
May 2, 2006 11:57 PM
