Fuel Tank question...
Old Nov 24, 2013 | 06:54 PM
fatboy1729's Avatar
fatboy1729
Question Fuel Tank question...
I have an 06 Fatboy F/Inj. Will someone know definetely if I can swap out the internals and flush mount cap and gauge from one tank to another? Both tanks are of the same model and part number. If so, how difficult a task is this to do? Is there any gaskets to replace or hardware? Sorry for all the questions. Just want to be sure. Thanks in advance for any replies...
Old Nov 24, 2013 | 07:35 PM
ChromeJunkie's Avatar
ChromeJunkie
It can be done but you will need the gasket and screws that connect the top panel to the tank. I used the drag specialities screws instead because they are about half the cost of the HD screws
Old Nov 24, 2013 | 08:10 PM
08Nighttrain's Avatar
08Nighttrain
If you are careful taking the first one apart you can reuse the gasket and screws. I have had my brothers swapped to a new tank and of again to check filter sock and still using the original no leaks.
fatboy1729
Dec 30, 2013 04:17 PM
fatboy1729
Jun 8, 2013 04:51 AM
groverhd
Dec 17, 2012 01:24 PM
GeorgeJ
Jun 16, 2007 02:07 PM
SPRINGER04
Feb 27, 2006 06:08 PM
