1997 Heritage Springer Help
Old Dec 18, 2013 | 06:10 PM
ruckus4offroad's Avatar
ruckus4offroad
Default 1997 Heritage Springer Help
Just bought this bike yesturday. I need to hook up the front turn signal lights. I found the part of the harness for the left and right front turn signals and just would like to know what the other 2 wires are used for.
Here is a picture of My ride:
Here is a a picture of what I need help with:
The purple wires are positive for the left and right turn signals. The signal lights are grounded through the frame. Where do the black and blue wires goto?
Old Dec 19, 2013 | 03:00 AM
piperbob's Avatar
piperbob
Black should be ground, blue running lights.
Bob
1997 Heritage
Old Dec 19, 2013 | 06:14 AM
Low budget Dan's Avatar
Low budget Dan
ruckus,
i found the same bike (97 heritage springer) for sale down the road from me owned by a women who seldom rode it not sure how long she has had it only problem we are miles apart on price she wants 15,000 i may be inclined to pay close to half of that. Without giving your price who is closer to reality, my opinion at that price it is going to sit a while
Old Dec 19, 2013 | 06:59 AM
hspring03's Avatar
hspring03
Front turns are also running lights. Dual filament bulbs for stock signals.
Blue is the run, purple is the turn, black is ground.
Can't go wrong on a Springer. Check out www.Heritagespringer.com
Old Dec 19, 2013 | 11:45 AM
ruckus4offroad
These after market turn signal lights are grounded through the frame. Also there is only a single wire coming from each front turn signal aswell. Do I hook up the running light wire and the turn signal wire together? The running lights must be at a lower voltage then the singals and thats what make it flash?
BTW I spent 8 thousand on this bike it has 44,000 miles and it sure isnt mint. My seller wouldn't budge on price That heritage looks like alot of money was out into it. Probably worth 10,000 or more.
Old Dec 19, 2013 | 11:47 AM
hspring03's Avatar
hspring03
Leave the running light wire (Blue) off.. Tape it up and leave it out. Be sure to check on Canada law. In Ma it's not required that they be running lights.
Old Dec 19, 2013 | 12:14 PM
ruckus4offroad
Is there a way I can hook it up? I would like them to be running lights.
Old Dec 19, 2013 | 12:18 PM
hspring03's Avatar
hspring03
I don't think you can without a dual filament bulb. The blue is sending constant power... I don't the turn will override that when you activate the directional. If you twist them together it will probably blow the fuse as soon as you flip the directional.
Might need to pick up fronts with dual filament and 3 wire configuration.
Old Dec 19, 2013 | 12:31 PM
ruckus4offroad
Think I could get a dual filament bulb for these housings?
Old Dec 19, 2013 | 12:38 PM
hspring03's Avatar
hspring03
Here you go... Might need to hunt around to see who has it.... Easier than trying to jury rig the housing.
http://www.kuryakyn.com/Products/870...urn-Controller
Ebay has them...
http://www.ebay.com/itm/KURYAKYN-FRO...7963cd&vxp=mtr
