used engine parts.....
Old Dec 20, 2013 | 09:35 AM
rgjujitsu's Avatar
rgjujitsu
Default used engine parts.....
Would you put used pistons cams and heads into your engine if the price was right? Why or why not?
Old Dec 20, 2013 | 10:39 AM
hspring03's Avatar
hspring03
I would use a set of heads or jugs if I was going to have them bored out or worked over.
I'd personally stay away from cams or pistons.. Were they installed correctly? Are they scored, damaged... etc.... Too many possibilities.
Old Dec 20, 2013 | 11:13 AM
moparbobby's Avatar
moparbobby
Back in my younger days that was the only way! never had a problem . A mans gotta do what a mans gotta do .
I don't do much of that anymore never had may 04 apart and hope not to
Old Dec 20, 2013 | 11:14 AM
Scuba10jdl's Avatar
Scuba10jdl
Pistons and cylinders, I would only use a complete set (pistons and cylinders from a previous engine) as long as I could verify the pistons matched to the cylinders. Even then I'd probably want to at least hone them and re-ring it.
Cams, sure as long as I could inspect them first.
Obviously, anything with excessive wear or damage is going to be scrap.
Old Dec 20, 2013 | 11:54 AM
rgjujitsu's Avatar
rgjujitsu
Thanks guys.
Old Dec 24, 2013 | 03:17 PM
oct1949's Avatar
oct1949
piston's in the same jugs, (but as said above, re-honed and new rings) lifters and push-rods in the same order front to back on the cams and valve's,
Old Dec 24, 2013 | 10:41 PM
Tom84FXST's Avatar
Tom84FXST
There are tons of "used" twin cam jugs and pistons on ebay that are like brand new because the owner just wanted to increase displacement...I would use them without a second thought.
TikTok
Nov 21, 2014 08:56 PM
prostar
Exhaust System Topics
Feb 1, 2012 04:20 PM
nosillyname
20
Dec 13, 2010 08:16 PM
Bluzmn59
Aug 8, 2007 09:37 AM
broke joker
May 4, 2006 11:55 AM
