Softail Height adjustment
Old Feb 4, 2014 | 06:32 PM
Ruggs59's Avatar
Ruggs59
Default Softail Height adjustment
I'm New to the softail shock....
My bike has been lowered (a little to much) If you were to look at this ebay auction
http://www.ebay.com/itm/2000-2013-Ha...-/271321875090
This is what i have under the bike now. (the added longer bolts) To raise it back up a little can i tighten the nut that is on the end where it goes thru the frame cross member? in effect to shorten the distance of the shock to the swingarm?
Old Feb 4, 2014 | 06:53 PM
jreichart's Avatar
jreichart
Yes, but you'll need to loosen the inner lock nut first (there is a double nut setup, one nut on each side of the shock support crossmember). Count the threads showing so each shock is adjusted equally.
Old Feb 4, 2014 | 07:07 PM
Ruggs59's Avatar
Ruggs59
Thank you, That's was what i was wanting to hear. I really didnt want to have to take them off and put it back with what ever was stock....thanks!
m1369x
Jan 17, 2020 10:42 AM
MICHALISLARNACA
Jan 6, 2016 05:58 AM
PaFatboy
Aug 12, 2012 08:47 PM
Gunna48
Jun 21, 2011 04:18 PM
Casybritt
Feb 10, 2008 01:36 PM
