Terrible "Clonk" when shifting into first
Old Feb 24, 2014 | 02:35 PM
thevirginian's Avatar
thevirginian
Default Terrible "Clonk" when shifting into first
Hey guys,
I have a '08 HS-classic with only 5k on the clock. Bought it used from local dealer. Was pretty much in like new condition when I bought it. When I shift into first gear after a cold start there is always a loud "clonk". After the motor has warmed up it is much quieter. My dealer says that is normal for Harleys. Now, last Saturday I test rode a brand new '14 STS and she was quiet. No "clonk". Is there anything that could be done to get rid of this loud noise? I also worry that something inside the gearbox could go bad, one day.
Old Feb 24, 2014 | 02:38 PM
Scrmnvtwins's Avatar
Scrmnvtwins
Relax, All is normal. Your clutch plates drip off all their oil when sitting for extended periods and after you go awhile the oil in the primary soak the clutch hub and plates again.
I find they clunk most if they are still on high idle after startup. If you can let it warm up a little to drop the RPMS's it might help.
Also, after you start it you might try pulling in and out on the clutch lever to open and close the clutch pack and get some fresh oil between the plates.
Old Feb 24, 2014 | 02:45 PM
flicksport1200's Avatar
flicksport1200
i agree scrmnvtwins , my 05 standard does the same thing on the first shift, in fact sometimes its hard to shift from first into second till she warm up then everything is good been that way ever since i had her
Old Feb 24, 2014 | 03:53 PM
wyndnface's Avatar
wyndnface
Its the nature of the beast
Old Feb 24, 2014 | 04:08 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
What goes clunk clunk clunk clunk clunk?
5 Harleys when the signal turns green.
Old Feb 24, 2014 | 04:10 PM
Nickatnyt's Avatar
Nickatnyt
Exactly what i was told by one of the techs at our local dealership, except he suggested the clutch lever be pulled before starting it.
Aaresz's Avatar
Aaresz
Yep, same here.
Old Feb 24, 2014 | 04:11 PM
soft 02's Avatar
soft 02
Sounds like the transmission and engine are going bad. Ill give you 5k for it.
Old Feb 24, 2014 | 04:20 PM
ntfreel53's Avatar
ntfreel53
Old Feb 24, 2014 | 04:51 PM
oct1949's Avatar
oct1949
everything is A ok,,
Its when she quits making the Clunk is when you come back and ask What's wrong....
