oil Temps
Old Mar 9, 2014 | 05:05 PM
mustang125's Avatar
mustang125
Default oil Temps
My oil temp was about 220 deg riding before I changed the exhaust from stock. It would climb rapidly when idling at a light. After The V & H Big shots were installed it ran about 210 and slowly climbed while idling at a light. Yesterday I changed all the oils to Redline synthetic. Today I went for a long ride and the temp never went over 190 on the trip while moving. Sitting at a light it would go up to 200 max. It sure is a testament to the quality of Redline oil!!! I also have no problem finding neutral and the clunk is greatly diminished.
Old Mar 9, 2014 | 05:34 PM
Shep68's Avatar
Shep68
I've been debating whether to go Redline or Mobile 1. Dealer sells a kit w/ RL oil for all 3 holes for around $110. Expensive oil change, but I've heard nothing but good things about it. I've got a 1000 miles to make my decision.
Old Mar 11, 2014 | 06:09 PM
mustang125's Avatar
mustang125
That is what I did. Don't forget the O-rings for the drain plugs and the oil filter are not included. Dealer charges $300 for a oil change with mineral oil. $135 for the oil, O-rings and oil filter was a bargain. I also have a cool funnel for filling the trans and a hat and stickers. What a deal!!! :-)
Old Mar 11, 2014 | 06:16 PM
mustang125's Avatar
mustang125
Drove To Birmingham today and had to idle in traffic. Temps never went over 210. A good oil makes a lot of difference! Before they went a lot higher with any idling.
Old Mar 11, 2014 | 08:39 PM
jimmers1817's Avatar
jimmers1817
Mal74's Avatar
Mal74
HD sells those little O-rings for a buck each. Here's a deal on ebay for 100 of them.
http://www.ebay.com/itm/100-PACK-111...a4e66d&vxp=mtr
Old Mar 11, 2014 | 08:47 PM
Mal74's Avatar
Mal74
you can't put Mobil-1 in all 3 holes. Go with RL if you want 1 oil. I use Amsoil myself. Either is good.
That dealer is raping you, charging 110 for the 'kit.' Even purging all the oil out of your motor you should only need about 6 quarts, and a filter. You can beat his price if you look around.
Old Mar 11, 2014 | 08:52 PM
1BRAVO9's Avatar
1BRAVO9
I don't have the problem with the temp but I definitely have the issues with the clunk and finding neutral. I would love to eliminate or reduce those problems. Anyone one else had these positive experiences?
Old Mar 11, 2014 | 08:59 PM
1004ron's Avatar
1004ron
Two areas that help with that is the oil grade in the Primary and in the Transmission.
I find the gear change clunk much reduced after going to the below oil combination.
Engine gets Mobil 1™ V-Twin 20W-50 every 5K - $9.60 at Meijer
Primary gets Mobil 1 Racing 4T™ 10W-40 every 5K - - $9.60 at Meijer
Transmission gets Red Line V-Twin Transmission Oil With ShockProof every 10K - $16.95 at Summit
I always use 1qrt of new oil to purge the engine at each oil change.
Old Mar 11, 2014 | 09:02 PM
1004ron's Avatar
1004ron
What was the ambient temperatures in each case?
Mine ranges between 175 and 225 degF depending on the ambient - same oil.
